Should i change transmission fluid?
Old Dec 20, 2007 | 09:32 PM
hoffdog's Avatar
I have an 03 2500 6 speed with 85k miles on it, i just bought it and was wondering if i should change the transmission/ differentials and what is the procedure on the transmission. thanks
Old Dec 20, 2007 | 10:14 PM
bluebull's Avatar
No service record, I would change the fluids anyhow just for peace of mind.
Just remove the lowest bolt on the PTO cover, this will drain the transmission. Replace bolt. There is a 17MM?? ellen plug just reward of the pto cover on drivers side you need to remove to refill it. Fill until fluid runs out, put plug back in, your done.
Use synchromesh type fluid.
Old Dec 20, 2007 | 10:20 PM
billie's Avatar
Rear diff gets changed every 25,000km on towing duty and never on light duty according to my manual. There must be some middle ground
I pull some and change every 50k. Front could probably go longer but its spinning all the time also. I do both.
Cya
Old Dec 21, 2007 | 07:37 AM
HOV's Avatar
HOV
There's a PTO cover on a 48RE??
I thought there was only one way to drain the fluid: pull the pan
Old Dec 21, 2007 | 07:39 AM
Hounddog's Avatar
He was asking about a 03 2500 6SPEED.That has a PTO cover and does not have a trans pan.
Old Dec 21, 2007 | 07:48 AM
HOV's Avatar
HOV
^^ Ah, well I missed that minor inconsequential fact!
markm4
Jul 29, 2007 11:16 AM
KillerBee
May 30, 2007 10:11 PM
99blackrig
Sep 25, 2006 03:44 PM
barracuda
Jun 14, 2003 10:40 AM
bdog
Dec 24, 2002 12:30 PM
