transmission fluid change questions
I am still trying to get the fluid changed in my tranny. Someone posted a link with this info: <br><br>These are the ONLY lubricants recommended for the NV4500: <br>75W-90 Castrol Syntorque Synthetic <br>Mopar Manual Transmission Lubricant (PN 4637579) <br>GM Transmission oil (PN 12346191) <br>NOTE: Syntorque is NOT the same as Castrol Syntech.<br><br><br>I have not been able to find any of these locally. The dodge dealer has the mopar but it is $28 a pint and I don't feel like spending $224 on transmission fluid. Seems like I remember reading a post a while back that regular 75-90 synthetic will work. I found some Mobile 1 75-90 synthetic - will this be ok? I don't want to mess up my tranny but I don't want to spend a fortune on fluid.<br><br>
Re:transmission fluid change questions
A friend of mine at the http://www.nwbombers.com just changed lube in his 6 speed from amsoil to 4 quarts of RedLine Manual Transmission Lube and said it made a noticable difference in shift smoothness. ;D
Heres some spec's<br><br>http://www.dodgeram.org/tech/transmi...v4500_spec.htm<br><br>This mite help
penzoil makes a oil that they recomend for the tranny its a little cheaper then the dealer and it will not hurt the synchros
The 5 speed and 6 speed use different fluid specs. Yes, the 5 speed Castrol Syntorq is a synthetic lube, 75W-90. I have Amsoil Series 2000 75W-90 in mine, and it was less than $30 for 4 quarts. It is GL-5 spec, and is designed to be compatible with yellow metals.
Was at my local ******* this morning and he had manual trans fluid on the counter. Asked him what it cost, $7 bucks a qt. Your ******* really is Da *******.
Unless you were seeking a different product. ???<br><br>Merry Xmas
markm4
Jul 29, 2007 11:16 AM
BuckBoardDriver
14
Jul 7, 2003 11:21 PM
