shifting gears
Old Dec 24, 2005 | 12:09 PM
StrokeThis2500's Avatar
shifting gears
at what rpmsshould i shift each gear can somebody help me not pulling anything and no load
2nd
3rd
4th
5th
6th
Old Dec 24, 2005 | 12:28 PM
drew03's Avatar
2000 unloaded. 2500 loaded. when loaded you want to be doing at least 1500 rpm's when you enter the next gear.
Old Dec 24, 2005 | 01:02 PM
good deal thats what i thought thats what i been doin but somebody told me diff but that just feels right
Old Dec 24, 2005 | 08:49 PM
spudman's Avatar
no way shift at the lowest possible rpm to get the next gear the max that i shift at unloaded is 1500. theres no reason for more unless you want to waste fuel mabye that why so many complain about low mpg.
Old Dec 24, 2005 | 08:52 PM
JCLeary's Avatar
I usually shift at 1700-1800 when running around town. I don't like to shift at 1500, because the transmission rattles a bit when revs are under 1200.
Keep your boost under 10psi, and egt's under 600 for the best economy (at least that's what I've read that Cummins recommends).
Old Dec 24, 2005 | 11:21 PM
bishgeo's Avatar
If you need to use the tach,maybe you should have bought an auto.
Old Dec 25, 2005 | 02:26 AM
Hounddog's Avatar
Cover the tach up and just drive it!
Old Dec 25, 2005 | 07:14 AM
Mike_Boutet's Avatar
Ussually around the 1700-1800rpm area. Too low and the tranny will complain, to high and your just wasting fuel. These are around town #'s, getting onto the highway is a different ball game.
Old Dec 25, 2005 | 08:46 AM
MikeyB's Avatar
I shift around 2k rpms. With the timing mod (Rokktech sensor) helps with the drivability at the lower rpms.
MikeyB
Old Dec 26, 2005 | 02:35 PM
hey hey watch ur mouth......
Old Dec 27, 2005 | 03:46 PM
bishgeo's Avatar
Ithought the big gauge on the left was the fun meter!!The higher it goe's the more fun I am having.I hope no one bought one of these trucks because of their fuel econemy.
Old Jan 1, 2006 | 09:03 AM
nickleinonen's Avatar
i'll shift anywhere between 1000rpm to 3000+rpm...
generally unloaded, it is around 1700rpm±200
Old Jan 1, 2006 | 09:33 PM
candndelivery's Avatar
Im glad someone finally said it, I've read many threads on shift points and have always thought it was silly, drive the truck by sound and feel not whats on the dash
Old Jan 2, 2006 | 08:38 AM
that counts for the speedo too for me although at times you look down and see 80kph in a 40kph zone then you get on the binders
Old Jan 2, 2006 | 11:02 AM
99 cummins's Avatar
If you shift without using the clutch for a while you will learn to feel it and find out where your trucks natural shift point is. This is not something to do all the time, but just to learn the feel of it and never loaded in these little ones.
