Shift on the fly!
Old May 5, 2005 | 09:02 PM
BA05'CTD's Avatar
Shift on the fly!
Has anybody had any problems with any of the componets on the SOTF **** on the dash?
Old May 5, 2005 | 10:06 PM
pcburnout's Avatar
no problems here and I use mine to my off road camp all the time. You bought a Dodge its a very simple design and there for the long run!
Old May 6, 2005 | 06:31 AM
Blue600's Avatar
No problems here either.
Old May 6, 2005 | 10:27 AM
v8440's Avatar
There was a thread somewhere a couple months ago about this. I don't remember if the thread was here or on another site, but I do remember that there were all sorts of folks yakking about "electrical stuff breaks" this that and the other. Everybody had a story about how they or someone they knew had a problem with non-mechanical transfer case shift setups...on a ford or chevy. Despite all the screaming and hollering against using anything other than a mechanical linkage, NOT ONE story ever surfaced about the current dodge electrical shift setup causing any problems at all. So no, if you have an electric transfer case in a 3rd gen dodge, rest easy.
Old May 6, 2005 | 12:15 PM
trik396's Avatar
No problems. In all of 1500 miles, I've used it only once.
Old May 6, 2005 | 12:18 PM
Peterbilt's Avatar
No problems at 30K miles. **** in same place as in my Ford which I don't care for, but ...
Pete
Old May 6, 2005 | 08:33 PM
pullin hard's Avatar
no prob with mine, has about 70,000miles
Old May 6, 2005 | 09:43 PM
Badunit's Avatar
No problems at 40K and 2+ years. There was a post somewhere where someone was thinking they were stuck in 4wd but it turned out they had bad axle joints at the front wheels. I've heard of no failures, just random talk about people trusting mechanical over electrical. If I'd had the choice, I would have chosen the old-fashioned lever too for that reason. Nonetheless, the electric version has been working fine and takes up less space.
Old May 6, 2005 | 11:14 PM
bill7975's Avatar
No problems 15000
Old Jun 1, 2005 | 01:35 AM
Tony Montana's Avatar
When I was shopping for my truck I didn't want the electronic 4wd, mostly because of what others here have mentioned: my experience has been that mechanical linkage is more reliable/durable than wires, electronics, and rubber hoses are. But, when I found a truck in my price range that had all of my 'prime directives' (CTD, manual trans, quad cab, long bed, 4x4) it had the electronic 4wd. Oh well I thought, the other stuff is more important.
However, one day I was working under my mom's 2000 CTD (fixing the 5th gear nut problem). It has the manual 4wd, but I noticed that the front axle has the same non-mechanical (I think it works on vacuum but I don't know that for sure) coupling for the front axle that my 2003 has.
Understand that to actually drive the front wheels the t-case must be shifted AND the split right front axle must be coupled together. This applies to both the manual and the electronic 4wd models. If the t-case is shifted, but the axle coupler fails to connect the front tires will not be powered.
So, the long and short of it is even the 'manual' 4wd system isn't truly manual. It has the same 'weak link' axle coupler as the electronic system (which actually has two 'weak links', but the axle coupler IMHO is the more vulnerable of the two since it's down on the front axle in the mud/snow/sand/etc)
Now don't get me wrong; you bet I'd prefer old school manually locking hubs and two shifters on the transfer case (one for 2wd/4wd and one for hi/low...there's times when low 2wd is pretty useful). But, the electronic system in my truck so far (frequent use over 30k miles) hasn't workeed flawlessly. And, my mom's truck has over 150K with no 4wd related problems. She doesn't 'off-road' per se but frequently needs 4wd to get to her house and so she uses the 4wd quite often. Both systems work perfectly well.
Old Jun 1, 2005 | 09:16 PM
Badunit's Avatar
Yes, the "manual" system on the 2nd gens had the vacuum motor as a failure point. The 3rd gens don't have that, the front end is spinning fully - shift the transfer case and it's in 4wd.
Old Jun 1, 2005 | 09:23 PM
runamuk's Avatar
NO! after my ferd failed me at the most in- opportune momnent I gave up on them but my Dodge seems to be much better engineered!!
Hopefully this trend will continue!
Old Jun 2, 2005 | 03:05 AM
v8440's Avatar
From what I've seen, this is not at all the case. I've been under my 04.5 several times, and have seen nothing on the front axle that would disconnect the wheels from the rest of the drivetrain. As far as I know, everything on the front turns right up into the transfer case while the truck is in motion, regardless of what's going in with the transfer case. In fact, I seem to recall several people saying that they removed their front driveshaft while chasing the 70 mph vibration problem down, and the vibration went away. The reason they did that is because the front driveshaft always turns, even when in 2wd.
Old Jun 2, 2005 | 03:42 AM
phox_mulder's Avatar
Yup, you are correct.
2002.5 on up.
phox
Old Jun 2, 2005 | 02:29 PM
Unhappy My Bad!
I got bad info on the 3rd gen system and hadn't actually checked it out for myself. Please accept my humble apologies.
