Serpentine belt tensioner?
Old Jul 10, 2008 | 01:33 PM
Dr. Smasher's Avatar
Is there a Serpentine belt tensioner on these models?
If not what ie the proper method fopr removng the belt?
Thanks
Old Jul 10, 2008 | 02:16 PM
rich's Avatar
yea their is its down on the passenger side assuming you have an 03 on up
Old Jul 10, 2008 | 08:13 PM
timcasbolt's Avatar
And if it's the original, you should seriously think about replacing it. Save the old one for an emergency spare.
Old Jul 10, 2008 | 10:53 PM
Jeff in TD's Avatar
The belt is a pain on these.
The tensioner is accepts a 1/2" square drive, and I think it's best to release it with a long ratchet from the bottom, and then slip the belt off of the water pump first.
You can't reach the water pump from under the truck, but in the past when I didn't have anyone to assist I've used a block of wood between the ratchet handle and crank pully to hold the tensioner in the released position.
creedeco
Nov 15, 2008 05:15 PM
woodrat
Oct 26, 2006 10:26 AM
banshee
23
Aug 16, 2004 02:20 PM
Commatoze
Oct 24, 2002 09:32 AM
