serpentine belt tensioner noises
Old Oct 25, 2006 | 09:01 PM
woodrat's Avatar
So I keep getting this intermittent squealing/squeaking noise from the belt. I was finally able to track it down to the tensioner pulley, but the noise is coming, not from the bearing, but from the belt occasionally riding over and rubbing up against the edge of the bracket. It doesn't always do this, but seems to be doing it more often than it used to. Is there something I can adjust to get that belt to ride in the center of the tensioner pulley?
Old Oct 25, 2006 | 10:43 PM
somis13's Avatar
just buy new. the shaft that the bearing rides on is probably excessivly worn. when its tite there will feel like there is no play. but with the belt off, you mite notice the pulley is able to move around a bit, but the belt cant go sideways.
Old Oct 26, 2006 | 10:26 AM
infidel's Avatar
When this happens it's usually because the pivot point that the arm rides on is worn, not just the pulley.
Replace the entire unit.
creedeco
Nov 15, 2008 05:15 PM
Dr. Smasher
Jul 10, 2008 10:53 PM
banshee
23
Aug 16, 2004 02:20 PM
Commatoze
Oct 24, 2002 09:32 AM
