Scan tools
Old Jul 21, 2007 | 07:53 PM
53 willys's Avatar
Originally Posted by Unit44
Looks like a good product, I noticed the good Chrysler expansion is on back order....
I bought the Powertrain Only version
works great.....
Old Jul 21, 2007 | 09:04 PM
J BODY's Avatar
yes I've been "shopping" for a scan tool of my own with a little more expandability. I've played with some of the "tool guy" scanners, but have found unless you spend at least 1K, they don't do enough to make me happy. Star scanners are still way high in price as well as old DRB's. The list of displayed items you listed looks really nice for the $$.
Old Jul 21, 2007 | 10:04 PM
jrussell's Avatar
Originally Posted by J BODY
Setpoint or target psi is what the ECM wants for rail psi. With the DRB you are able to monitor what the ECM wants and then are able to see that the "mechanical" side of the fuel system is able to deliver by watching the "fuel rail psi". Driving along simply monitoring rail psi would be nothing more than "eye candy" with out it. Crusing you might be around 10k psi, but when you throw it to the floor your "setpoint" can go as high as 25K psi and your rail psi should follow that reading quite quickly. Acceleration overshoot, lack of power due to fuel rail psi can be seen using these two readings. Setpoint will always vary due to rate of accel, load, etc....
Ok, I gotcha.
Knowing that target info is definitely useful (and necessary for serious troubleshooting), but saying the gauges/monitors are "nothing more than eye candy" is not really true. You can still see if you're draining the rail or not because we know the psi should increase at to a certain point at WOT. If your pressure goes from 23k to 17k at WOT you know you have a problem. 99% of the rail pressure issues are related to modding, so IMO the gauges/monitors are very useful.
I don't really see a need to constantly monitor rail pressure though. Once your truck is setup and you know the pressures are good then nothing should really change. That's the major reason I went with the laptop scan tool instead of a rail only gauge.
Old Jul 21, 2007 | 10:35 PM
53 willys's Avatar
Originally Posted by jrussell
Ok, I gotcha.
good point Justin
so you gonna call them about the 2second update time or should I???
Old Jul 21, 2007 | 10:50 PM
jrussell's Avatar
good point Justin
I'll call if I can remember sometime Monday!
Old Jul 21, 2007 | 11:24 PM
vzdude's Avatar
DTR's 'Go to Guy'
However, having a guage monitored all the time can help you know in advance if something is going wrong. Like a leaking rail relief valve, cps cascade valve, leaking injector......... I know where you're coming from, but I prefer to have mine available at a glance.
Old Jul 22, 2007 | 12:36 AM
J BODY's Avatar
...unless something else is causing a fuel de-rate. In that case you would see your "setpoint" is also at the lower reading pulling fuel back. Keep trying to convince me otherwise. I am open to new and exciting items for these trucks.....but so far IT'S EYE CANDY
Old Jul 22, 2007 | 08:02 AM
jrussell's Avatar
Either way, you still see there IS a problem from the pressure drop. If your truck is defueling at WOT for no reason you DO have a problem.
If you think it's eye candy then that's fine, don't buy one. The fact is it is usefull for most of us to see how our mods affect rail pressure. Mark also showed that the enhanced version shows the rail pressure setpoint if you really needed to know it.
Old Jul 22, 2007 | 09:41 PM
J BODY's Avatar
....and that certain "point" would be.........SETPOINT!
I know, I know...your done here. I'm a stupid dealer tech...would you expect any less??
.....and to be honest with the way downloaders, piggy back chips affect the data it may all be hocus pocus I'd be looking at anyway. If I suspect a downloader I'll flash the ECM so it is on the same page as I am.
Old Jul 23, 2007 | 09:48 AM
jrussell's Avatar
I understand what you're saying, and I appreciate the info you posted because I didn't even know there was a setpoint until you mentioned it.
Like I said before, I agree the setpoint would absolutely be needed for serious troubleshooting. However, not knowing the setpoint doesn't automatically make the gauge reading useless. It's no secret, we know the max rail pressure under WOT should typically be around 24-25k (give or take). If you add a bunch of mods and suddenly it starts going down to 17k at WOT, then you know you have an issue with draining the rail. The gauge will tell you this and that's why it's not just "eye candy" for most of us.
kyle_truck_pull
May 28, 2009 02:38 AM
Smooshy
Jan 30, 2008 09:07 AM
lifer
Dec 26, 2007 10:44 PM
BDR2500
Jan 18, 2005 04:55 PM
TEXASTURBO
Mar 16, 2004 05:03 AM
