was running low on fuel and threw a code p2146
Old Apr 30, 2008 | 08:42 PM
itr.#1446's Avatar
I was just running low on fuel and have the fass system so on an incline i guess it picked up air and bogged out and almost stalled, then i threw a code for p2146. I guess its because i had no fuel but how do i go upon resetting the codes? I hope it will just go away once i fill up and not pop on again.
Old Apr 30, 2008 | 09:07 PM
BlackPuff_Gone's Avatar
After three good trips the MIL is extinguished and the Task Manager automatically switches the trip counter to a warm-up cycle counter. DTCs are automatically erased following 40 warm-up cycles if the component does not fail again.
For misfire and fuel system monitors, the component must pass the test under a Similar Conditions Window in order to record a good trip. A Similar Conditions
Window is when engine RPM is within ±375 RPM and load is within ±10% of when the fault occurred.
Old May 1, 2008 | 03:59 PM
itr.#1446's Avatar
i also have an edge does that have anything to do with it? i have been searching and see everyone has this problem with the edge
Old May 1, 2008 | 07:07 PM
Beats me. I copied my reply out of the manual. Maybe someone else knows.
Old May 2, 2008 | 08:40 AM
Diesel-Dude's Avatar
I've had this come on twice. If you want the "check Engine" light to go off, simple disconnect the batteries for a few minutes. When you hook them back up, it'll be out! I also have the Edge, but never had this issue until I had the "hot" upgrade a year and a half ago. I contacted Edje and they said they were aware of the problem and were working on a solution, but that was a year ago and I haven't contacted them to get a follow-up. Maybe shoot them a line and see what they say.
snowmanx
Jan 13, 2012 06:56 AM
gerdes15
Feb 25, 2008 03:26 PM
