royal purple in transfer case and diffs?
ok i'm wanting to change the lube in my transfer case and front and rear diffs. wanting to know how much does it take in each and what weight to be using???
i don't think they've ever been changed
I just changed my diffential fluids this past weekend and the numbers quoted by CountryBoy are accurate. I'm not towing much and with winter coming on I opted for the 75W90 in both diffs.
One thing to remember, the used fluid really stinks, I don't even know how to describe it. Anyway, if you can do it in a well ventilated area (outside) I would recommend it.
I did it in my garage, and after about a half hour I really didn't notice it, but my wife complained about the smell the whole day.
TRANSFER CASE: ATF +4
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205FD 1.6 L (56 oz.): 75W-90 Gear Lubricant
9 1/4 AA 2.2 L (74 oz.): 75W-90 Syn. Gear Lubricant
9 1/4 AA EL 2.0 L (6.8 oz.): 75W-90 Syn. Gear Lubricant
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.) *** Synthetic Gear Lubricant 75W-140
10 1/2 AA 2.5 L (85 oz.) 75W-90 Syn. Gear Lubricant
10 1/2 AA EL 2.5 L (85 oz.) 75W-90 Syn. Gear Lubricant
11 1/2 AA Open 4.2 L (142 oz.) 75W-90 Syn. Gear Lubricant
11 1/2 AA Trac-Rite 4.0 L (135 oz.) 75W-90 Syn. Gear Lubricant
248RBI (DANA 60) 2.8 L (46 oz.) **** Gear & Axle Lubricant SAE 90
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
**** Add 147 ml (5 oz.) of Limited Slip Additive
** Includes 0.9L (1.0 qts.) for coolant reservoir.
Recommends Mopar Fluids
I use RP 85w140 in the rear but I live in the Sonora pizza oven. I also used it in Co. with no drawbacks whatsoever from cold, stiffness or mpg. I also got the best UOAs from the 85-140. I'd use a minimum of 75w140 in the rear diff for the better lubrication. RP SynchroMax is the best I've used in the 6 spd.
dslpwr81
63
Apr 28, 2008 12:38 AM
Roperteacher
Jul 15, 2007 07:11 PM
Strjock81
23
Jan 17, 2007 10:29 PM
