Rocker Box Gasket
Old Mar 25, 2008 | 02:01 PM
sawboywv1's Avatar
Rocker Box Gasket
Gents, I'm going to replace the "weaping" rocker box gasket at next oil change. I picked it up today at dealer and this one is Rubber!!. The original looks to be paper??? I have not torn it down yet, but does that sound correct. They check the # 3 times for me. Maybe the new one is rubber and has been upgraded. The org. one weaped almost from day one.
Thanks
Old Mar 25, 2008 | 02:59 PM
MR. GADGET's Avatar
MIne to, and it is rubber from the factory.... It leaks more in the cold bigger change in the metal, I just clean it from time to time. I have talked to people that replaced them and had the same thing happen after they wasted a lot of time on it. Remember you need two one for the bottom and one for the top. You have a O ring on the head then the lifter block, one more O ring then the cover. If one is leaking then the other is too I would bet.
Old Mar 25, 2008 | 04:53 PM
Hounddog's Avatar
Had mine and others that post on this site had theirs replaced under warranty.No issues since.Mine was like two years ago.Was told it only takes a slight amount of roll on the rocker box seal to cause a leak.It pays .8 to do under warranty flat rate.
Old Mar 25, 2008 | 05:03 PM
MR. GADGET's Avatar
IS that under the 7 year 100k warr?
Old Mar 25, 2008 | 05:15 PM
Hounddog's Avatar
YEP.Years 6 and 7 have a $100 deduct.0 through 5 do not! I would suggest it be done after truck left night before.I'd rather that rocker box be torque cold if the book dosen't mention it.
Old Mar 26, 2008 | 03:29 AM
PourinDiesel's Avatar
It's an easy change for either gasket 10-30 minutes tops.
sawboywv1
Mar 10, 2008 01:31 PM
wildchild97
Sep 25, 2007 02:44 PM
04ctd
Oct 5, 2006 08:27 PM
BearKiller
Feb 20, 2006 11:29 PM
fearthedeere
Feb 9, 2006 06:38 PM
