RH Pull cured on mine!
Old Jan 24, 2004 | 05:29 PM
Gypsyman's Avatar
Thumbs up RH Pull cured on mine!
After trying a MILLION different alignment settings I went to a tire shop and had all of the directional tires turned the right direction, (yes, 4 of the 6 were backwards from the factory). PRESTO, for the first time since I've owned the truck it drives perfect and NO MORE RIGHT HAND PULL!!!
Old Jan 24, 2004 | 06:17 PM
DPG's Avatar
DPG
What brand tires, Gypsyman?
Old Jan 24, 2004 | 06:20 PM
Gypsyman's Avatar
Factory "Goodyear Wrangler GS-A's"
Old Jan 24, 2004 | 07:28 PM
DPG's Avatar
DPG
Thanks, Gypsyman!
Old Jan 26, 2004 | 07:36 PM
RickE's Avatar
I don't think Goodyear GSA's are directional...but you need to mount them so the edge with more rubber is on the outside. The "A" stands for asymmetrical.
Old Jan 26, 2004 | 11:36 PM
Gypsyman's Avatar
The GSA's are directional. Each tire is clearly labeled "This Side Out" and they are not asymmetrical.
Old Jan 27, 2004 | 12:14 AM
RickE's Avatar
Gypsyman,
That is NOT directional. "This side out" will work on both left and right side of the truck. The wheels will turn in the opposite direction with the same side out.
Directional tires have an arrow to show direction of rotation. You have to remount them on the rims to move from left to right side.
I had GSA's on my Ford. Once mounted on the rims correctly, they can be rotated to any wheel position. The outside is always on the outside. They rotate in opposite directions on opposite sides of the truck.
I'm sorry if this isn't clear...I'm no English major.
Old Jan 27, 2004 | 12:20 AM
RickE's Avatar
Asymmetrical means not symmetrical. There's more rubber on the outside edge of the tread. The lugs are more open on the inside. BTW, I didn't like the tires very well. Snow traction wasn't very good.
Old Jan 27, 2004 | 01:41 AM
Gypsyman's Avatar
I mistated what I meant by calling it directional, we're on the same page, I'm just crappy at stating what I mean. You are absolutely correct on all counts.
Old Jan 27, 2004 | 09:37 AM
Mopar_Mudder's Avatar
So you are saying that you had one side on with white letter out and one with black letter out? I don't recall them be white lettered both sides.
Old Jan 27, 2004 | 05:24 PM
RickE's Avatar
Gypsyman, I'm glad you got rid of your pulling problem. They actually mounted the tires with the wrong side out? Where's the quality control?
NJMurvin
15
Dec 7, 2009 05:17 PM
Haulin_in_Dixie
Jun 1, 2005 09:59 PM
F. Flack
Aug 30, 2004 12:49 PM
wannadiesel
Apr 1, 2004 07:40 PM
