revolutions
Old Jun 18, 2004 | 02:59 PM
padiesel's Avatar
revolutions
How do I find out how many revolution a mile my tires go around? The Dodge guys at the garage were unsure on how to do this....
I have 35 x 12.5 x 17 pro comps.
What is the formula?
the correct answer is between 400 and 900 rev per mile.
Old Jun 18, 2004 | 03:39 PM
cquestad's Avatar
probably close to 600....look up the manufacturers number at load.
Old Jun 18, 2004 | 06:34 PM
bulabula's Avatar
The easiest way (without math) I've found is to go to www.tirerack.com and look up the specs on the tire.
If you've got a calculator and tape measure, measure the circumference. Convert that number into feet and divide it into 5280. That'll be close enuf for govt work. pi*d works for circumference too, but there's more guess work due to the contact patch on where you measure it from.
You're guess between 400 and 900 rev's/mile is spot on. I'd put my money on 600 too.
Old Jun 18, 2004 | 08:09 PM
gcssr's Avatar
Thumbs down
tire size 35 in. times 3.1416=109.965 Divide by 12=9.163
5280 divided by 9.163= 576.23 r p m.
If my math is right
Old Jun 18, 2004 | 09:28 PM
bulabula's Avatar
But 35's aren't really 35's.
According to tirerack, BFG 37/12.5/17's are 574 revs/mile - note that the dia is really 36.3". I'll still stand by the 600.
Sort of like when the queen realizes that rulers aren't necessarily 12".
Old Jun 19, 2004 | 05:40 AM
padiesel's Avatar
Thanks guys I believe on the 600 too! I think that is what I will set it at!
Old Jun 19, 2004 | 12:00 PM
toddbweaver's Avatar
Revolutions per mile
The way I do it is to mark the tire on the bottom part of the sidewall closest to the ground with a vertical line and mark the road at the same point as you do the tire. Then drive the vehicle forward or backward one revolution. Mark the road again and the take a tape measure and measure the distance between the 2 marks on the road. This is about as accurate as you can get.
Old Jun 20, 2004 | 06:49 AM
padiesel's Avatar
tire is cool if they sell your tire! Thanks guys your help is appreciated!
true revolutions is 599. I had a buddy that is a cop clock me on a new calibrated radar gun at 65mph it showed me at 64 so I think that is **** good!
dieselcarpenter
Nov 17, 2007 12:24 AM
jfisher04
15
Jan 31, 2007 08:32 AM
jfisher04
Jan 26, 2007 07:33 AM
mxboy
Aug 28, 2004 05:27 AM
