Retrieving Codes?
Old Jan 14, 2007 | 08:52 PM
drooperhaley's Avatar
Retrieving Codes?
I've read that there is a procedure for retrieving codes without a scanner but cant find a description of the procedure. I take it that it involves turning the key off/on in some sequence. Would someone be good enough to refer me to the procedure or post it here?
TIA,
Bruce
Old Jan 14, 2007 | 09:08 PM
bdewey's Avatar
to look at codes on the newer dodges you have to turn the key from off to on 3 times and then on the third time hold in on position. Do all this without turning over truck. If any codes are stored they will come up and then read **Done**.
Old Jan 14, 2007 | 10:03 PM
THANKS!
Bruce
Old Jan 15, 2007 | 12:47 AM
TexasCTD's Avatar
And once you look them up, here is a list of most of the codes.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Hope that helps!
Old Jan 15, 2007 | 10:44 AM
Hope that helps!
Thanks, I very much apreciate it!
Bruce
ogopogo
Feb 20, 2007 09:10 AM
Tee
Jan 25, 2007 09:20 PM
Holy Goat
Aug 25, 2006 08:46 AM
amartinson
Aug 25, 2004 12:52 PM
neo_in_2199
Dec 6, 2002 01:15 PM
