Replaced CSS still getting P0336 now what?
Old Apr 11, 2009 | 12:02 PM
cincydiesel's Avatar
Ok guys, after running around all over town to get a crankshaft sensor I'm still getting a P-0336 code.. I replaced it and truck still has a hardtime starting and still getting the code.. Any ideas would be great!!
Old Apr 11, 2009 | 08:44 PM
BigIron70's Avatar
Cummins Guru
Sounds like it could be a wiring problem. Any other codes setting? Is the code active meaning does it come back on as soon as you clear it? Do you have a good multimeter and know how to use it? Possible Causes
CKP SENSOR
(K24) SIGNAL CIRCUIT OPEN
(K853) 5-VOLT SUPPLY CIRCUIT OPEN
(K975) RETURN CIRCUIT OPEN
(K24) SIGNAL CIRCUIT SHORTED TO (K975) RETURN CIRCUIT
(K853) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K975) RETURN CIRCUIT
(K24) SIGNAL CIRCUIT SHORTED TO (K853) 5-VOLT SUPPLY CIRCUIT
(K24) SIGNAL CIRCUIT SHORTED TO GROUND
(K853) 5-VOLT SUPPLY CIRCUIT SHORTED TO BATTERY NEGATIVE
INTERMITTENT CONDITION
ECM
Old Apr 11, 2009 | 09:14 PM
BigIron70's Avatar
Cummins Guru
Also check speed indicator ring behind crankshaft damper if damaged will set code.
FastTaco
Apr 19, 2014 10:34 AM
hotdram
21
Aug 4, 2008 09:26 AM
hotdram
Jun 17, 2008 08:16 PM
B.A.Ram
Jun 3, 2005 12:17 PM
