Removing Lift, Going Back To Leveled.
After having my 4" lift on for the past 6 years I may be dropping it back down to a leveled stance again.
I have just a real basic Tuff Country 4" lift, blocks in the rear, spacers in the front, the control arms and the longer pitman arm. I found a local guy with an 05 that has his truck leveled. I 'm pretty sure it would be a simple swap but I just wanted to make sure we wouldn't run into any thing weird along the way. All of my components will bolt right up for him correct?
We'll just have to swap control arms, pitman arm, spacers up front, shocks, rear blocks and mounting hardware.
Anything else i'm missing here? Thanks.
it will be a total swap. only thing that might cause a struggle is the corrosion issue and some bolts might be a pain to get loose but that is it. u-bolts in rear should be replaced though but those are cheap
Nick660
Aug 7, 2006 03:44 PM
JoshPeters
Apr 3, 2005 08:13 AM
97CTD
Feb 24, 2003 05:00 PM
