Removing leveling kit, need alignment?
Old Apr 6, 2008 | 02:11 PM
jballou's Avatar
I am planning on stepping down a few tire sizes and removing the leveling kit from the front. The truck seems to be aligned correctly now yet when I remove the kit is there an alignment in my future? 50% or to dark and smokey to tell?
Don't know cause the truck came with the large tires and leveling kit.
BTW what rpm's would the truck be at with 265/70's and 3:73 in OD @55? Stock set up.
Old Apr 6, 2008 | 04:32 PM
TAS05CTD610's Avatar
Not sure what tranny you have, but I have the same size tires, gear ratio, and the 4 speed auto, and at 75, I'm turning around 2100 rpm. 55 it would problably be like 1400-1600.
Old Apr 6, 2008 | 04:57 PM
jballou's Avatar
Well currently with the auto and 35" toyos @ 55mph it turns 1350 rpms.
Old Apr 6, 2008 | 04:58 PM
rjm022's Avatar
just installed my 1.5" spacer lift today! lengthened the trac bar by 3/16 of an inch- truck tracks down the road perfect!
Old Apr 6, 2008 | 05:28 PM
OOPS's Avatar
The toe-in should not change, the caster will. See how it handles and go from there. If the return to center is not right of it gets death wobble, take it in.
Old Apr 6, 2008 | 07:39 PM
no_6_oh_no's Avatar
Toe and caster will both change. Getting the toe correct is pretty tough and is critical or you will trash the tires. Caster is not as critical but too much will cause weird tire wear also. You best bet is take to an alignment shop.
Old Apr 6, 2008 | 07:48 PM
92'1stGen's Avatar
55 mph w/3.73 & 265/70 = 1500 rpm
Old Apr 6, 2008 | 08:59 PM
jballou's Avatar
Thanks everyone.
O5DodgeRam5.9
Jun 24, 2010 09:02 PM
rsscoggins
Jun 23, 2007 07:56 AM
jkravito
Aug 7, 2006 09:45 PM
dwhite
17
Feb 26, 2006 06:25 AM
IsItFast
Oct 16, 2005 12:30 PM
