Rebuilt engine fuel leak
Old Sep 12, 2013 | 01:19 PM
Txbigfoot's Avatar
I just put in a rebuilt motor. it didnt fire up initally. Turned out #4 fuel line was leaking like a seive. i replaced it with a new one from Cummins. only $24!! Dealer wanted $70! The new one has a all metal bracket and it looks pretty beefy. The engine fired up right away and was doing great for the first 5 mins. Then I started to see a pretty good fuel leak that was dripping down the tranny/ engine junction. #4 looks dry and I cant see a fuel leak from the CR. I have not checked the injectors that came with the motor ( that was going to be my next step after I got the install done). i did see a coupe of little drops going down one of the lines next to the fuel filter but not the leak that i saw earlier.
My question is this:
Is it possible it is a stuck injector and that there is a high return flow that is leaking somewhere? There was a delayed return to idle when you gave it a little fuel.
What should I do next??
Any constructive thoughts would be helpful . It has been 4 months with no truck and I would love to see her purr again
Old Sep 12, 2013 | 06:18 PM
Spooler's Avatar
Did you check the fuel return on the back of the head?
Old Sep 12, 2013 | 08:12 PM
BigIron70's Avatar
Cummins Guru
leak is most likely on the low pressure side, since a leak on the high side would cause a no start or the fuel would be misting,
Old Sep 12, 2013 | 09:05 PM
Txbigfoot's Avatar
Where do I find the return hose? Do I need to crawl up under the hood to find it? Is it safe to drive it to the dealer leaking?
Old Sep 12, 2013 | 10:29 PM
Spooler's Avatar
It is on the very back of the head. I you have injector leak due to a bad injector or crossover tube seal, this will return the fuel to the tank. It's a banjo bolt on the back of the head. They may have left a copper washer off.
It's not the PRV valve on the rail.
Old Sep 12, 2013 | 10:36 PM
Spooler's Avatar
Here is a picture if I can get it to post. See it at the back of the engine.
Old Sep 12, 2013 | 10:45 PM
Spooler's Avatar
Little better pic.
Old Sep 14, 2013 | 12:18 AM
Txbigfoot's Avatar
Thanx for the picture! turned out the #6 fuel line was the culprit. Now no more leaks. dNow I am just puffing lots of blue smoke Not sure what to make of this yet. Truck runs great ( or so it seems). no error codes. Any ideas? Head was rebuilt and I was told new rings were placed.
Old Sep 14, 2013 | 11:48 AM
Spooler's Avatar
Check your turbo's seals. I would also call the folks who rebuilt it. Did you install it, or someone else?
Old Sep 14, 2013 | 02:14 PM
Txbigfoot's Avatar
I had called the guy who rebuilt it., he said he put new bearings in and new rings. i had a guy install the motor for me. how do youcheck the turbo seals??
Old Sep 14, 2013 | 08:01 PM
Spooler's Avatar
Just pull the air cleaner intake off and look inside at the compressor wheel. To inspect the exhaust side you will need to pull the downpipe off.
Old Sep 24, 2013 | 12:53 PM
Txbigfoot's Avatar
when i pull off the air cleaner and te downpipe what will i be looking for?
Old Sep 24, 2013 | 06:02 PM
Spooler's Avatar
Engine oil.....
corygale
Jul 31, 2009 06:40 PM
ramsport59
Feb 21, 2008 10:30 AM
lauranull
May 24, 2007 11:57 PM
tilyn62
Aug 26, 2005 04:21 PM
banks twinram
27
Jan 13, 2005 06:53 PM
