Rebuilding the 48re
Old Aug 18, 2007 | 09:12 AM
TORQUE BEAST's Avatar
Rebuilding the 48re
I have rebuilt trannies before (350,400 turbo,700r4,c6) but not the 48re. Just wondering how hard they are to do and if you need any special tools or not or if I should just let someone else do it. I have talked to dusty and dave but still not sure exactly what I'm going to do. Both are super nice guys but I like the fact of lifetime warranty on the tc from dave. So lets hear it---do it myself or let someone else?
Old Aug 18, 2007 | 02:44 PM
t-boe's Avatar
When I talked to Dave he said if you have rebuilt any auto the 48re is pretty simple. It's basically a similar version of the torqueflite.
Old Aug 18, 2007 | 05:15 PM
That's kinda what I was thinking but wasn't sure. I'm leaning toward doing it myself.
Old Aug 19, 2007 | 02:53 AM
Sprinter17's Avatar
Muted User
Try it yourself, I lay everything out on a board with saw horses, it's actually fun. Last time I rebuilt a GM 4l80e, and went all out and replaced the pressed in bearings, so I took certain pieces to a tranny shop that had the correct jigs to press bearings. They asked me why I was changing out the bearings. I guess all they change are the seals and plates.Good thing is ,they didn't take any money, not even a tip for pressing the parts out. Save some headaches, search on line for the hand tool that helps you compress the seals to get the clutches back together without tearing a seal.
Old Aug 19, 2007 | 11:48 AM
thanks for the tip. I'll do a search for it.
Old Aug 19, 2007 | 12:19 PM
J BODY's Avatar
http://www.atec-trans-tool.com/product-listing.asp
I had access to all the goodies at work, but basically found the following tools on this link necessary.
T-1318, T-1301, T-3210
Old Aug 19, 2007 | 01:41 PM
XLR8R's Avatar
Go for it!
Just don't do a "drop the pan in the garage valve body shift-kit quickie rebuild" or it'll probably sound the death knell for the tranny...
Old Aug 19, 2007 | 03:04 PM
goose2w1's Avatar
Just download a service manual at http://hemitruckclub.com/. No special tools are really needed excpet at a minimum a 3 ton arbor press o take apart the overdrive unit to replace the clutch packs.
Old Aug 19, 2007 | 06:29 PM
J BODY's Avatar
....The tools I listed come in pretty handy for OD disassembly/assembly. Aligning the splines in the OD. Measuring end play for proper intermediate shaft end play spacer....and measuring for correct OD piston thrust plate thickness.
B&W Ram
14
Dec 11, 2008 09:27 PM
belfert
May 8, 2004 07:33 AM
banzaitoyota
Oct 9, 2003 11:15 PM
dsljunkie
Jul 21, 2003 03:09 PM
tlea7
Mar 5, 2003 11:48 AM
