rearend dodge/chevy
New Venture, now New Process, was a joint venture. AAM was a captive GM supplier, now a separate public company. Wouldn't be surprising if the 10.5 and 11.5 14 bolts look the same btwn GM and Chrysler but have minor differences; not sure how to find out for sure without dissecting a couple or good luck getting AAM to divulge that info.
From what I've been told, the differences between the Dodge AAM 11.50 and the GM AAM 11.50 is the size of the brake rotors and the limited slip diff. It used to be a popular mod to put the limited slip diff from the GM rearend(which is NOT a GovBomb, BTW) into the Dodge rearend. The limited slip diff in the GM AAM 11.50 is a Torsen type whereas the Dodge version is a clutch pack type. I hope this helps you out a bit.
Scott
Scott
Scott
Scott
The Dodge is the one with the torsen style "Trac-Rite GT" diff. http://www.aam.com/index.php?s=49&item=99
The GM G80 is indeed the dreaded Gov-Bomb....although the 11.5 may be better the the earlier design. My scrap barrel is full broken ones, if that's any indicator of thier durability.
http://www.ringpinion.com/PartsList....b-Differential
I've replaced several from the 8.5 rear end (which is undersized to begin with) but I've never seen a broken one from a 9.5, 10.5 or 11.5
I'm not saying the Eaton is the strongest unit but it flat works as designed.
The TracRite certainly has it's own limitations.
Scott
Scott
i forgot my camera.... but fyi on open carriers atleast the gm cros pin in mayby 1" vs the dodge@ almost 2"....
and like tony said... the gm got the g80 gov bomb... chrysler got the torsen type.
pleas dont make me spend all night finding the old pics catalogs data sheets etc here,,,,
next thing you know we'll have jt on here claiming he has 3.42's on the shelf for the 11.5......
gm has small brakes, thin axle tubes, weak carrier etc....
You are mistaken.
Scott
wreedCTD
27
Sep 30, 2007 09:52 PM
95black2615
19
May 24, 2006 11:05 AM
