rear end
Old Aug 26, 2005 | 11:59 AM
RamTough277's Avatar
rear end
does someone have a pic of the carrier in the rear (prefreably the passenger side of the carrier) . i need one to see how bad mine is? i dont think there is supposed to be holes and spider gears showing out the sides? ive got some pics of mine if that might help someone that might have seen the inside of these rear ends.
does anybody have (save on thier computer of course) this section of the repair manual that they could email at aandjtransport@sbcglobal.net. i'm going to attempt this myself.
Old Aug 27, 2005 | 12:11 AM
bump
Old Aug 27, 2005 | 08:44 AM
nickleinonen's Avatar
i am not quite sure what you mean about holes in the sides of the carrier??? do you mean where the bearings in the ends of the carrier are? there are holes in the preload adjusting nuts on both sides of the carrier where you set your backlash and preload..
PM also sent about the service manual...
Old Aug 27, 2005 | 09:59 AM
on the right side of the carrier has holes where the spider gears has worn through, well that is what it looks like me. i can email you a pic if it would make any easier. its hard to explain.
thanks for the pm
Old Aug 27, 2005 | 10:00 AM
Crazy T/A's Avatar
I just removed my rear cover yesterday (to change the gear lube) and noticed the same thing with mine. It had metal slivers hanging off where the spiders look like they have worn through the limited slip housing, 4 half moon spots. I called the dealer and they want to look at it. I found a few metal shavings in the bottom of the diff. and the oil was black and had a metalic look to it.
Old Aug 27, 2005 | 10:16 AM
yep and howled bad. my diff cover is burnt (paint bubbles). pics are in the my gallery.
Old Aug 27, 2005 | 06:23 PM
that carrier picture #2 doesn't look right. it looks like either the carrier was machined wrong or it was rubbing somewhere.
Old Aug 27, 2005 | 06:44 PM
Red1ton's Avatar
Ram Tough277...just changed my diff. gear oil... mine (carrier) didn't look like that, but my diff. cover had blistered and peeled and I had to scrape and repaint it...but I had to do the same (scrape & repaint) within a couple thousand miles after I first bought my truck. !!! Hey.. Crazy T/A how many miles on your truck??
Mine has 20k
Old Aug 27, 2005 | 07:58 PM
i had thought it was rubbing somewhere to but theres nothing for it to rub on. ordered the parts today new carrier,ring and pinion, all the bearings and seals - $1100.00
Old Aug 29, 2005 | 09:45 AM
Crazy T/A's Avatar
Mine has 20k
15,000, it's a 2004.5
RamTough277, that is exactly how mine looks.
Old Aug 29, 2005 | 09:59 AM
Mr. Jimmy's Avatar
There is 11.5 inch AAM on ebay with 300 miles on it out of wrecked truck, last time I checked it was at $750.
Old Aug 29, 2005 | 03:48 PM
i already ordered all the parts. just got find torque specs and back lash settings. going to tackle it in the drive this weekend.
Old Aug 29, 2005 | 04:04 PM
Mr. Jimmy's Avatar
Ramtough 277,
I can send the 11.5 rearend section of manual if you've got a Fax number. shoot me a PM
Old Aug 29, 2005 | 08:28 PM
thanks
Old Aug 30, 2005 | 03:15 PM
Mr. Jimmy's Avatar
Ram tough 277,
check these links out, you'll probably want this on a CD.
handymantim
Senior Member
Member's Photo Gallery
My Classified Ads!
I'm going to look in my 2004 manual but while I'm looking you can go to:
http://www.hemitruckclub.com/03DRM.pdf for the 2003 manual or
http://www.hemitruckclub.com/04manual/ for the 2004 manual.
Mr. Jimmy
