rear drive shaft
Old Feb 1, 2008 | 02:49 PM
pullin hard's Avatar
rear drive shaft
anyone have problem with their rear drive shaft and flange/yoke?
i have been going through u joints like every month or 2, seems that the rear yoke flange has a twist in it.when i installed the u joint into the yoke,either cup goes into yoke no problem, but when one is installed first it is the other end that it gets tight, seems to be twisting the u joint. the drive shaft is not as bad, but same thing there too. the ears are twisted slightly. so when the joint is in both the drive shaft and yoke(together) the u joint tends to get tight, which makes it fail, causing a vib.
just wondering if anyone else had this happen, or if any one has had a new aftermarket drive shaft made with better tubing and bigger or better yokes?
any one have a rear yoke they want to sell me ?
Bradleysram
Feb 25, 2009 11:07 PM
jj3500
Jun 28, 2008 07:36 AM
grandblanc
Jun 28, 2008 06:56 AM
slowwheelin
Oct 1, 2007 08:16 PM
