Rear differential overheating on hard pulls
Old Jan 1, 2018 | 01:00 PM
barbed wire's Avatar
when pulling 36 foot horse trailer in mountains rear diff gets super hot and pushes fluid out pinion seal. diff not noisey and very little play when drive shaft rotated.
Mabe heavier diff grease?
Old Jan 1, 2018 | 01:10 PM
deere country's Avatar
Originally Posted by barbed wire
when pulling 36 foot horse trailer in mountains rear diff gets super hot and pushes fluid out pinion seadiff not noises and very little play when drive shaft rotated
I have no idea what a seadiff is but I assume you were referring to the pinion seal? I wonder if your axle vent tube is plugged?
Old Jan 1, 2018 | 02:00 PM
Busboy's Avatar
I have seen where a pinion seal is leaking badly but rather than replace the seal someone has drained the oil and actually put grease into the rear end just to sell the vehicle. The oil should be a synthetic gear oil at least 75w90 and 75w110 if you are towing hard.
Old Jan 2, 2018 | 11:45 AM
BILTIT's Avatar
Vent tube plugged or problems in diff.
Old Jan 3, 2018 | 06:57 AM
she's going into the shop gotta be a bearing or something to cause that much heatThanks
Old Jan 12, 2018 | 06:24 PM
Pinion bearings discolored. Been hot. Replaced pinion and carrier bearings.
Should be good to go.
Old Jan 12, 2018 | 06:26 PM
Pinion bearings discolored from heat. Replaced pinion and carrier bearings. Should be good to go.
Old Jan 13, 2018 | 10:26 PM
So did you determan a cause for the oil getting hot?
Old Jan 15, 2018 | 06:34 AM
Pinion bearings were discolored from heat.
Old Jan 15, 2018 | 07:33 AM
I get that part but, they don't get hot for no reason. Their was a cause that allowed them to get hot.
What is going to prevent them from getting hot again if their was no cause determined?
Bersaglieri
Jul 31, 2007 12:44 AM
~Angry Tractor~
Dec 16, 2006 08:44 PM
Bobcat698
19
Nov 3, 2005 10:40 PM
Turbo Deeezle
Jan 20, 2005 06:46 AM
