Rear differential fluid all foamy?
foam=air between the gears, not oil. that is bad. its some what comon when the oil has got hot and broke down. last time i filled mine i used Richman Gear synthetic fluid, next change will see Redline severe gear oil, its the equivelent of a 50w-250 oil... yes you red that right.. not a typo..
all new gears run hot durring break in.. the aam's are diferent from the dana's in the fact they only have .003-.005" back lash vs the dana .007-.012".
the cut of the gear is entirely diferent alowing a much larger contact patern and for the teeth to clide acros the gear face much easyer...
so larger surface area generating heat = more heat to have to disapate, not nesasaraly a bad thing, once broke in theres less friction and les heat.
besides, if your gear oil cant handel a sustained 235 deg get a diferent fluid..
600? realy?
i cant think of a single gear oil, synthetic or not designed to run in this range???
as a fyi, we generaly paint dif covers at work with crylon, it generaly burns off between 250-275, we use it as a tattletale to see if the dif has been overheated durring breakin ...
we also do our own in house r&d..... i;d have to look back but i dont recall ever seeing a diff over 400, even towing durring breakin..
600? realy?
When I put a mag h pan on the rear dif the factory stuff was all milky looking too. Like the lower unit oil on a boat with a bad seal. Other posts on this site said that was typical of factory fill so I went ahead with install and refilled with mobile 1 syn.
This is a great thread. I with I could chime in with some answers. All I can say is that when I first changed my diffs the fluid looked like it has seen better days.
I put the Valvoline synthetic 75-140 in the rear and 75-90 in the front; we’ll see how they look at next change.
With foam like that and grey oil normally I'd say the cause was water intrusion, but it seems its somewhat normal on these trucks. When I did mine I didn't have any foam, but the oil definitely had a grey tint to it. I figured it was from lubes used during manufacture and assembly.
Have you set the backlash differently to require this? I've had good luck with Redline shock-proof and severe duty oils, but always had unique reason to require it. An oil that heavy sure will suck up a lot of power.
garrett
A little off topic but I see under bluebulls heading he's been banned, what happened? I've read many of his/her posts and learned alot. Maybe a little ruff around the edges but seemed to know his/her stuff.
Mike L
Jul 2, 2010 10:06 AM
blakedill
Nov 23, 2005 09:22 AM
