foamy transmission fluid???
Old Nov 22, 2005 | 06:11 PM
blakedill's Avatar
So second dodge and second transmission with foamy fluid. This one only has 30,000 on it and I have only had it 3,000 miles. Has anyone else had this problem???
Old Nov 22, 2005 | 06:29 PM
apc's Avatar
apc
Foamy fluid is caused by high level?overfilled
Old Nov 22, 2005 | 06:41 PM
rjm022's Avatar
overfilled!!
Old Nov 22, 2005 | 10:46 PM
blakedill's Avatar
I would be willing to bet that is the problem.
Thanks
Old Nov 23, 2005 | 07:19 AM
bluebull's Avatar
Check fluid level with truck warmed up at least 10 miles. Check in neutral on level ground. If fluid is high you better drain some out or you'll be going in for a third tranny. Also smell the fluid if it is dark or if it smells burned replace imediately.
Old Nov 23, 2005 | 09:19 AM
05mxdiesel's Avatar
Not to hijack the thread, but when I changed the diff oil in mine, the rear was really foamy, so it must have been a hair over filled.
Old Nov 23, 2005 | 09:22 AM
Geico266's Avatar
Not to worry, that's normal.
Dlowkes7
Dec 17, 2010 07:37 PM
4x4not
29
Apr 9, 2008 05:46 PM
gt4660
Mar 1, 2007 12:38 AM
MARKY MARK
Dec 8, 2005 05:54 AM
bigsam
Feb 7, 2005 12:32 PM
