Rear Diff Make?
Old Jun 27, 2009 | 10:13 PM
wiskeyVI's Avatar
Rear Diff Make?
Can anyone tell me if the rear ends on the 04 are the same as the 06?
Thanks
Old Jun 27, 2009 | 10:45 PM
TonyB's Avatar
If I recall correctly, 2003 was the changeover year for AAM diffs. American Axle & Manufacturing.
HTH
Tony
Old Jun 28, 2009 | 12:58 AM
Spooler's Avatar
Yes they are the same. AAM They are also the same for 03-09. Just check the gears. They may be different.
Old Jun 28, 2009 | 03:40 AM
TexasCTD's Avatar
I believe some of the "SO" trucks in 03 and perhaps early 04 had 10.5'' ring gear AAM axles. The rest all came with 11.5'' ring gear AAM axles. FYI.
Old Jun 28, 2009 | 07:13 AM
RiverRat2's Avatar
So the truck in my sig should have 11.5" Diff W/ 3.73 gears?????
Old Jun 28, 2009 | 09:35 AM
TonyB's Avatar
11.5" diff: yes
3.73 gears are possible; 4.10 was the other option
Is there a label still on the diff? It may have been worn off by now. The other thing to do would be to have the dealership pull the build sheet - give them your VIN.
Tony
Old Jun 28, 2009 | 10:05 AM
RiverRat2's Avatar
Originally Posted by TonyB
11.5" diff: yes
Tony
Thanks,,, is your tranny an Automatic
Old Jun 28, 2009 | 12:41 PM
TexasCTD's Avatar
Unless something has changed recently, the G56 only came with 3.73 gears..........4.10s were an option only on the autos.
Old Jun 28, 2009 | 01:40 PM
RiverRat2's Avatar
Hey thanks T'CTD,,,
Did you install the Exhaust brake on your truck or did it come on it???
Old Jun 28, 2009 | 08:21 PM
TonyB's Avatar
Yup.
Old Jun 28, 2009 | 08:36 PM
wiskeyVI's Avatar
Thanks Folks. That info helps.
RiverRat, if the question about the exhaust brake is to me, yes I installed the PacBrake myself.
Old Jun 29, 2009 | 01:06 AM
TexasCTD's Avatar
Hey thanks T'CTD,,,
N E time. I did install the PacBrake Air bags.. but unfortunately I don't have an Exhaust brake yet. Maybe someday.
afate45
Jun 7, 2014 12:08 AM
krazydher
25
Apr 15, 2010 12:37 PM
banana
Dec 1, 2009 11:44 PM
big red psd cc
Dec 30, 2005 11:29 AM
wood_n_soldier
18
Jun 24, 2004 08:10 AM
