Rear axle seal questions
So yesterday I'm busy replacing the rear main seal housing, rear main seal and clutch when I see a little puddle coming from the drivers side rear tire.
GREAT!
This morning when I came out to the parked truck, the rear axle has leaked quite a bit of fluid! Enough to travel down the driveway a few feet!
Couple questions:
1) I just got new tires and wheels of the truck last Friday (about 600 miles ago). There is nothing a tire shop could do to cause the rear axle seal to go out is there? I really don't think they could do anything, but figured I'd check.
2) anyone know what size the hub nut is on the rear? I need to rip into this and take care of it (hopefully this week some evening) but I want to make sure I have everything I need before getting into it. I hate (and she does to) jumping into the lady's car all dirty to grab parts.
GREAT!
Couple questions:
Totallyrad posted very thorough and detailed thread about how to do the exact job you are needing to do. The nut you are asking about is 2 9/16", but it is my understanding that, if you are careful, you can use a punch to break the torque that is on it, then use your hands to remove it. I also understand that this nut is actually very similar to putting on a nut on a trailer axle wheel bearing. I did some research on the net about this particular nut installation, and I'll be installing it in a similar fashion to the trailer wheel axle bearing method, but with much more precaution and precision. I just see justifying the cost of this special socket for a job that one may only do once, maybe twice.
This is just my humble opinion, and I'm sure others will have a different one.
With as much stuff as I get into, I'll probably just buy the socket. And now that I think about it, I think I have one from doing front seals on my 2nd gen dully.
RTillery
Feb 7, 2009 08:46 AM
pwrtripls1
Jan 7, 2008 08:55 PM
dieseljerk
Jul 8, 2004 07:23 AM
