Rattle with RP Fluctuation
Looking for some help here, this is one we haven't seen before.
Have an 04.5 manual truck that has a cyclic rattle at idle. Every 7 seconds or so, it has what sounds like an injector or lifter rattle. Hooked up to the scan tool, this sound corresponds to a change from 5500psi (ish..normal idle pressure) to a spike of 10-13kpsi. I suspect the noise is the injectors rattling or a return valve rattling. The cause is the question.
I am leaning to the FCA as the cause. Any thoughts or similar experiences?
Thanks!
Thanks!
Erik,
I have the same noise with my ride. It is more predominant in the morning, but I can hear it all the time until I reach approx. 7psi then it goes away....but it comes and goes bout every 5-10 sec, almost like a vibration rattle????
my 2004.5 started to make a rattling noise that seamed to come from the from the number one fuel line. when the engine makes the tapping noise it also can be felt. it did not give any codes at first but a day later p0251 then after unplugging wires at back of cp3 it spit out a p0088. then driving home the engine light came on. still runs fine. i parked it until i get it figued out. i am thinking maybe bad number one injector , one mechanic said possibly a cracked injector. i pull a lot without any mods other than an s&b air intake.
This sounds very similar to a rattle that my truck has been making lately. It likes to do it in the morning before it gets warmed up and at no to small amounts of boost. However I dont have a rail pressure guage so I cant tell what the rp is doing? But after the truck gets warmed up, then noise fades away. Eric or 2007 5.9, does this sound like similar symptoms to the issues related with your truck? Did just an FCA fix the problem completely?
Do you think that since it happened after you installed your injectors that they had anything to do with it?
I,ve got to give you my opinion on this one. You lucky buggers with a rail pressure gauge (next mod) can be sure if your seeing a 2000 psi difference at idle your FCA is going. That is if your not stacked with multiple fueling chips/downloaders. For the others with a rough vibrating cold start idle you have got carbon build up on your tips, ruining the spray pattern causing a screwed up idle. I know it has happened to me many times. Nature of the cummins medium duty industrial engine in a pick-up. I'm still on the oem fca due to the fass filtration. I don't care what system you got on your rig but get the fuel supply filtered down to 3 microns or better. Carbon will still build up as most of us don't work these motors as designed. By the way hot rodding quick light to light won't clean the tips of varnish&carbon build-up. Only thing I have found is towing/hauling loads with sustained egt's over 900F..........
What a load
Feb 16, 2005 01:10 PM
Haulin_in_Dixie
Jan 7, 2005 04:28 PM
PHX_ATC
Nov 23, 2003 01:38 PM
Gordonville
Apr 1, 2003 04:36 PM
