QuickCheck II
QuickCheck II
I work for an engineering agency and one of my coworkers worked for cummins back in the day. He gave me a QuickCheck II J1939 converter with everything. Will this work for my '06? I could only find info for 2nd gen stuff.
im at work so cant take any pics now, it came with one cable that plugged into the unit(phone line looking) and had a 3 pin flat(thinking male end). It also came with 2 adapter harnesses, one that has a female flat 3 to triangular deutch type connector(we use this at CAT across the board) and another that I cant remember. Ill take a pic later. Not really sure where the can data link is located on these trucks. Near the ECM im guessing. Ordered a palm III last night for $20 of ebay
I can get the part numbers for ya when i get home also if that helps you.
well I look at a cable a buddy has and it won't work. I thought we might be able to read through the OBII port? any more Ideas. Would really like to get in there and take a loo around
Thanks,
Scott
Thanks,
Scott
Here are the pics
The one is the unit which is part of the "QuickCheck II Dodge" PN 4025391 and the main harness 4021286. The other pic shows parts 4005949 and 4005948, the adapter harnesses im guessing.
http://i152.photobucket.com/albums/s...y/100_0489.jpg
http://i152.photobucket.com/albums/s...y/100_0491.jpg
I thought some chips tap into the data link. Where is that connector under the hood?
edit: found it on quadzilla's site
http://www.quadzillapower.com/downlo...3-06_Dodge.pdf
Looks like harness 4021286 and the adapter 4005949 will work
mstep3
Jul 11, 2010 05:49 PM
