quick help with terminalogy?
Old Jul 26, 2008 | 11:08 AM
choppers555's Avatar
i need to go to autozone and get the stuff you put on bolts that seals fluid from coming out. for example the tapped hole where you install your temp reader for your trans gauge. i can't remember the correct terminalogy?
Old Jul 26, 2008 | 11:10 AM
dozer12216's Avatar
Teflon tape or thread sealer or proper tightening on good threads.
Old Jul 26, 2008 | 11:12 AM
thank you, and thats not the same things a locktight correct?
Old Jul 26, 2008 | 11:14 AM
OOPS's Avatar
Thread sealer-----Lock-tite makes some.
Old Jul 26, 2008 | 02:44 PM
Jeff in TD's Avatar
Loctite 565 is a tread sealer good for up to 300 degrees, and corse threads.
567 is good for 400, and 5770 is rated for 530 degrees.
Old Jul 27, 2008 | 07:59 AM
timcasbolt's Avatar
I like Indian Head shellac compound for sealing bolts. Comes in a small brown bottle about 1 1/4" diameter by 3" tall. Last I checked, it cost about a buck and could do a whole motor with a little left over.
Old Jul 27, 2008 | 08:22 AM
rjm022's Avatar
permatex #2
skydiver41
Jun 16, 2006 10:32 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
AKDSLDOG
Apr 1, 2003 02:33 AM
jet
Dec 6, 2002 09:11 AM
Haney
Nov 25, 2002 11:26 AM
