Question about transfer cases
Old Apr 8, 2021 | 08:00 AM
vrt93's Avatar
My NV273 has decided that it wants to keep having electrical issues so I've decided I want to swap in a 271 and have the manual shift. I have a line on a couple used junkyard units, but one is behind a 48re and the other is off an nv5600. does anyone know if the input shafts for those are the same as my g56 or will i have to crack the cases and swap shafts?
Old Apr 8, 2021 | 08:46 AM
rockcrawler304's Avatar
The Dodge Np271 uses either 23 spline or 29 spline input. Your G56 has a 29 spline output shaft so as long as you get the 271 that uses the 29 spline you should be good.
Old Apr 8, 2021 | 11:05 AM
vrt93's Avatar
Do you know what spline count the nv5600 or auto trans uses?
Old Apr 8, 2021 | 02:04 PM
The 5600 in a 4x4 has the 29 spline shaft. The 4x2 would have a 31 spline shaft. The 48Re has the 29 spline
NO_SPRK
Dec 12, 2011 09:25 AM
Dean Snow
Sep 16, 2011 08:33 AM
Southern Pride
Feb 7, 2008 09:02 AM
rhino 660
Apr 22, 2007 10:26 PM
clc900
Nov 18, 2004 07:46 PM
