Problem with truck
Old Feb 22, 2009 | 10:01 AM
Megadeth's Avatar
Problem with truck
So this morning I cruise over to my dads, hook up the snowmobile trailer while my truck is idling then it starts idling all rough and sounds like it'll die with the check engine light, then goes back to normal for a min, then back to rough.. so I shut her down, put the smarty to stock and still does it.. checked my codes (on the edge) and it says bank 2 (cylinders 4-6) shorted.. hmm. anyone know whats up?
Old Feb 22, 2009 | 10:04 AM
rich's Avatar
06 and 07 wire harness to the injector can rub causing a short to the injector bank buddies o7 5.9 did it to him. if you take the valvel cover off the wire harness has its own gasket set up where the wire feed thru check them for rub spots or if its under warranty take it to them
Old Feb 22, 2009 | 10:28 AM
Megadeth's Avatar
So is it safe to drive? At least home or to the dealer? I doubt they'll warranty it cause of the edge but ill see unless it might be something else.
Old Feb 22, 2009 | 10:50 AM
rich's Avatar
you can pull the edge off. should be fine to drive he drove his to the dealer. what you described is exactly what he told me
Old Feb 22, 2009 | 03:57 PM
Megadeth's Avatar
Has anyone else had this problem?
Old Feb 22, 2009 | 06:09 PM
6.7L OneTon's Avatar
I had a shorted #5 wire from the factory on my 6.7. They replaced the gasket (and the harness that way) and it was fine. It did however take them 4 trips and me getting stranded twice for them to figure it out.
Tingram
Jan 15, 2009 09:38 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
