Problem with bucking 06
Old Apr 26, 2007 | 12:49 PM
PolisHammer's Avatar
It looks like I have a slight problem with my 06.
On the open stretch of the road at constant speed (80mph) the truck from time to time will just buck. It feels like for a split of a second it will go into 3rd, or like someone shuts of the fuel and then reopens it. You are accelerating the strong jolt/brake - face on the windshield and it picks up right away like nothing happened. I have no idea what it might be. Does that makes any sense?
Old Apr 26, 2007 | 12:53 PM
dodgezilla04's Avatar
can you do the key on/off 3 times back to on and check for any codes on the odometer?
Old Apr 26, 2007 | 01:08 PM
I have checked for the codes with Juice and Predator, both say "No Codes"
Old Apr 26, 2007 | 01:14 PM
try removing 1 mod at a time and see if it goes away. that will help you narrow down posibilities
Old Apr 26, 2007 | 01:16 PM
That's probably what I have to do, but I have had them on for a while and no problem till recently.
Old Jul 8, 2007 | 10:33 AM
silver bullitt's Avatar
My truck does the same thing and the dealer can't find the problem. Go figure.... Anyone have any suggestions? This is very annoying and only happens every once and a while. Stock truck and is really noticeable while towing...
Thanks
Old Jul 8, 2007 | 11:10 AM
Hooligan6's Avatar
Mine started that way also, now it does it all the time I've taken it to multiple shops and changed out thousands of dollars worth of stuff over the past few months. I still have not found the problem! Read some of my last threads and you'll see some of the suggestions that other members had they may work for you.
Old Jul 8, 2007 | 01:18 PM
03dodgeoffroad1's Avatar
well the predator might be your problem do you have the new update for it they fixed the surging isuses i think go to the website and check it out
http://www.diablosport.com/index.php...e6b5e01d82a25f
Old Jul 8, 2007 | 02:09 PM
Dodgezilla's Avatar
Yup, your Predator is most likely the culprit. Mine did that once but has not done it again.....
Old Jul 8, 2007 | 03:39 PM
I have a stock 04.5 that bucks in cruise control or normal driving. Really driving me nutz and the dealer says no codes are to be found. Oh the great computer age where a tech can only diagnose a problem with the computer. The techs theory is no code no problem. I take him for a drive and he says how can I find the problem if the computer cant
HELP
Old Jul 8, 2007 | 04:42 PM
Hooligan6's Avatar
This seems to be an issue thats not real common but is a real pain in the butt.After driving all day I'm physically sick to my stomach from all the surging.I think I'm going to get some sea sickness pills if I can't figure this one out soon!
Old Jul 10, 2007 | 04:04 PM
btolenti's Avatar
I had the same exact problem with my Diablosport Predator....the newest update fixed it.
Old Jul 11, 2007 | 12:55 AM
fathertime's Avatar
surging
had areal bad surge in my 04.5 3500..drove me nuts ...chrysler reflash did not help 3 different shops couldn't find anything also no codes...finally a good local shop pds diesel here in chilliwack b.c fixed it..says he's done 3 lately..fuel temp/preasure sensor on back of injection pump 177.00..smooth as glass..he says fuel preasure in rail was up and down over 2000 psi...hope this helps
Old Jul 11, 2007 | 01:58 PM
Hooligan6's Avatar
I'll check that out thanks for the input
Old Jul 11, 2007 | 09:20 PM
danc46's Avatar
The problem comes from too many digital sensor inputs changing at one time. The ECM will momentarily "stutter" before going back to the input protocol.
Simply put, too much stuff happens for the electronic brain to process at one time.
firehawk
Apr 11, 2013 09:15 AM
YOUNG GUNS15
Jun 28, 2009 10:03 AM
blackduallie
Jun 21, 2006 06:34 PM
joel
Jan 7, 2003 10:18 AM
Eat Beef
Dec 19, 2002 12:03 PM
