power steering problem please help
Old Sep 20, 2008 | 01:42 PM
lmurphy's Avatar
Power Steering Problem Please Help
Three times now the steering has slipped or caught at parking lot speed when turning sharply. It feels like the steering pump losses power for a second then it catches and is fine. Another way to describe it is it feels like a power steering belt slip on on old model vehicle. I can hear/feel a clunk also. Any experience with this from anyone else? Iwould like to diagnose and fix before it causes problems. Thanks for any help.
2005 dodge, 4x4,quadcab, 2" spacer kit, 38,440 miles on odem.
Old Sep 20, 2008 | 02:55 PM
Jim Dynomite's Avatar
When you turn too quick at low speeds and the steering gets stiff for second........its a good indication that your pump is going out.
My 06 has had 2 pumps in 30k.
Mine got so bad I could barely turn the wheel driving to the dealer.
The PS pump also supports the booster for the brakes, so don't let it get bad.
.......Jim
Old Sep 21, 2008 | 09:07 AM
lmurphy's Avatar
Thanks for the reply. Does anyone on here know a good Dodge dealer mechanic that I could call to ask about this. Thanks for any help. LM
Old Sep 21, 2008 | 09:58 AM
mitternocht's Avatar
I wonder if it could be the nature of our front ends and the 4x4 system? Since the front driveshaft is always spinning even when you are in 2wd, when you turn the wheel at slow speeds it can cause the font axle and driveshaft to accelerate their rotation.
All of this would be driven off the power steering pump, so if it were getting weak it might magnify the effect of the weak pump?
Old Sep 21, 2008 | 05:13 PM
dozer12216's Avatar
Dealer has a PS pressure and flow tester that does good job of diagnoising. A slipping belt is also a possibility.
Old Sep 21, 2008 | 05:46 PM
NickBeek's Avatar
Mine has done this from time to time since new. I now have 76K miles on her. I'm gonna say nature of the beast.
Old Sep 21, 2008 | 11:30 PM
BigIron70's Avatar
Cummins Guru
I had a control valve in steering box causing similar problem. Would loose power assist on right turn at any speed. Brakes still worked fine.
Old Sep 22, 2008 | 10:26 PM
lmurphy's Avatar
How did you or the dealer fix that problem? New box or was it repaired? LM
Old Sep 23, 2008 | 01:30 PM
BigIron70's Avatar
Cummins Guru
Replaced the steering box. Had this same problem with two trucks. Replaced steering box on both trucks fixed problem. Had no power assist when turning right, left turns were ok. Was covered by warranty.
littlebuddie
Nov 22, 2012 06:07 PM
Gary d.
Aug 29, 2010 08:44 PM
DHT
Apr 2, 2010 07:12 AM
tatkins85
Jul 15, 2008 10:39 PM
SuperiorRam
Mar 15, 2007 03:10 AM
