Leaking power steering Fluid BAD. Help Please.
Old Jul 11, 2008 | 08:17 PM
tatkins85's Avatar
ok guys ive been putting the leak off but now its undrivale. it leaks way to bad to drive because if i go on a long drive ill leak it empty. ill post some pictures in a second. but anyways can you guys guess whatsa wrong? could something of broke or is it commin for something down there to come loose? or whats up i need some ideas because i need to fix it so i can drive. please help guys. i think the leak is comming from the top of the power steering box? but could be wrong heres the pictures.
Old Jul 11, 2008 | 08:52 PM
JOESHTRDDSL's Avatar
I had a leak that looked a lot like yours and it turned out to be the o ring between the p/s pump an tank. It looked like it was coming from the steering box because it drips straight down onto it. I removed the tank and replaced the o ring and have had no leaks in 5k miles. Hope this helps and good luck.
Old Jul 12, 2008 | 07:34 AM
Blue600's Avatar
I just replaced my gearbox last weekend due to it leaking from the pitman arm shaft. It too was leaking so bad I couldn't drive it. Came on quick too.
Old Jul 12, 2008 | 09:39 AM
jivemother's Avatar
quick fix , i used lucas stop leak my box was leakin bad from the steering shaft end used about 50/50 mix works like a champ
Old Jul 15, 2008 | 10:39 PM
JThiessen's Avatar
There was a TSB on steering box's for the early models (I know my 03 was covered by it).
zippitta
Apr 4, 2014 06:27 AM
amercier4
Jun 15, 2009 02:57 PM
Tommy93w350
Jun 26, 2007 04:42 PM
Rpainter
May 27, 2007 08:31 AM
bigragu
Nov 4, 2005 04:31 PM
