Popping sound at 50mph
Old Mar 16, 2016 | 11:29 AM
red truck's Avatar
I am hearing a popping noise from the back end when in 5 th gear above 50mph. It is not constant in time between pops. Feels like something gets caught or stuck and releases. Anyone had this issue before? Standard transmission.
Thanks
Old Mar 16, 2016 | 11:38 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
We need to know what year truck you have and which transmission...for us to accurately comment
Old Mar 16, 2016 | 11:41 AM
red truck's Avatar
Yep, that would help- it's a 2003 dodge 2500 cummins turbo, standard transmission
Old Mar 17, 2016 | 04:25 PM
sct5024's Avatar
I guess an easy thing would be to see if your u joints are good.
Old Mar 18, 2016 | 08:18 AM
BigIron70's Avatar
Cummins Guru
It depends on which trans you have NV4500 5 speed trans or a NV5600 6 speed trans. Possible 5th gear nut is coming loose or gear is slipping on the NV 4500 common problem. If that's the case you do not want to drive it since it will damage trans until gear is replaced and new nut installed. REF SB 21-10-98 Rev. A If you only hear noise in 5th gear most likely the problem, do not use 5th gear if you need to drive truck.
gfuller999
Jun 23, 2007 07:48 PM
dgm
Jan 2, 2006 10:26 AM
Gene007
Dec 23, 2005 01:20 PM
olivmatt
Dec 19, 2003 07:00 AM
nailzsn
Jun 8, 2003 11:12 PM
