View Poll Results: Intervals, non synthetic.
Less than 7500
121
44.32%
7500-9000
65
23.81%
9000-11000
38
13.92%
11000-13000
1.47%
13000-15000
2.20%
Oil gets better with age!
1.47%
I use synthetic because my truck is too good for the regular stuff
35
12.82%
Voters: 273. You may not vote on this poll
Poll, how long are you going between oil changes, thinking of upping my intervals.
Old Dec 11, 2007 | 12:43 PM
Rednecktastic's Avatar
Thinking of going to 10K on oil and fuel filter. That way I only have to get dirty once every few months.
Also wondering what good oil filter I should use with my Delo 15-40.
This pertains to pure petroleum only NOT SYNTHETIC! Although I'll put that option so you can voice your opinion .
Also, who uses the oil analysis labs and how much do they cost.
Post your service duty and answer below if you want....
Old Dec 11, 2007 | 12:47 PM
cbrahs's Avatar
have you been taking oil samples before hand? I just go to the local kenworth dealer and buy kits $18 and some change, then go to UPS and mail them off in 1 box. shipped a box yesterday that had front/rear diff and t case. cost $7 and some change. will be sending engine oil out on the 20th when I change oil. I am not going to extend my oil change past 5000 until i start sending in samples and let them tell me it is ok to go further plus i am installing an amsoil bmk-11 bypass system. have a friend that has that system on her truck and each oil sample comes back cleaner than the last.
Old Dec 11, 2007 | 12:49 PM
No, I'm only on my second oil change 07 5.9L. Think I'll go to 8500-9000 this time and send in a sample.
Old Dec 11, 2007 | 12:52 PM
cbrahs's Avatar
I would stick to the interval you have now and wait for a sample to come back. the place you send the samples to should recommend an extension but might want some history first. would rather be safe than sorry.
Old Dec 11, 2007 | 12:56 PM
Truckman0097's Avatar
Same year and engine, my first change was done by the dealer, so no oil sample, my second change was done by me, and I sent in a sample - oil had around 7,000 - 7,500 miles on it, can't remember exactly - I sent in a sample to Blackstone, they came back and said to extend my next change to 8,500 - 9,000.... FWIW
I would recommend sending in a sample before you start extending, all trucks and engines break in and wear differently, so going by what someone else does may or may not be a good idea....
Old Dec 11, 2007 | 01:01 PM
RocketJohn's Avatar
i just do it at 5k in my garage... easy to remember...
Old Dec 11, 2007 | 01:11 PM
matego's Avatar
madhat's monkey boy...
Like you said, all engines and driving habits are different. I have approx 40k on my truck but do not tow. The last sample I had the TBN was 7 and soot was 161 with Premium Blue at 10k on the oil. It was well within spec to run to 15k but I change it at 10k normally. I will change it at 5k when I spend time at the drag strip. I figure it is the least I can do for my engine after I thrash on it.
Old Dec 11, 2007 | 02:58 PM
SundayMoney's Avatar
My OCI is 7500.
Old Dec 11, 2007 | 03:18 PM
ptgarcia's Avatar
7500 miles here. Do the fuel filter at the same time so I don't forget about it.
Old Dec 11, 2007 | 03:57 PM
RocketJohn's Avatar
how much is the Premium Blue synth? the non-synth is $10/gallon...
Old Dec 11, 2007 | 04:27 PM
staarma's Avatar
I do the oil and fuel at 5k. I use Rotella T 15/40 all year and only Fleetguard Stratopore filters for both oil and fuel.
Old Dec 11, 2007 | 04:31 PM
skynyrd's Avatar
i change mine at 10k along with the fuel and oil filters and running rotella 15/40 but 90% of my mile are on the highway and i drive 100 miles a day.
Old Dec 11, 2007 | 04:35 PM
rjm022's Avatar
20,000 miles between changes-using amsoil 15w-40 oil and their bmk-11 single oil by pass set up.
Old Dec 11, 2007 | 05:35 PM
dodgecbr600rr's Avatar
use john deere 15w40 dyno oil. heavy towing few times a month. change oil every 12,000km or 200 hours which ever comes first.
Old Dec 11, 2007 | 05:42 PM
tufamc's Avatar
every 5k 15-40 shell, unitll winter (below 40) then 5-40 shell, but I dont drive more than 3000k in winter (october-april) then back to 15-40.
