Plugs and Wires
Old May 30, 2006 | 08:28 AM
Toto's Avatar
Plugs and Wires
Hi All
I have a 2004 305 555 and I figure it is time to change the spark plugs and ignition wires.
Does anybody know where they are...any pics...I can't seem to find them?
Old May 30, 2006 | 08:37 AM
mtl0727's Avatar
i believe they are located between the reverse transmission fluid reservoir and the blinker fluid reservior.....not sure though ill let an expert chime in on it though
Old May 30, 2006 | 09:17 AM
Shadow Caster's Avatar
Hum?
What kind of engine are you trying to change the spark plugs in?
Old May 30, 2006 | 09:20 AM
jkitterman's Avatar
On a diesel, they go by a different name. Plugs = injectors and wire = injector lines. Replace both sets together and you should be just fine.
Old May 30, 2006 | 09:46 AM
P.J's Avatar
P.J
Plugs and wires should be good to go, might want to think about swapping out that muffler bearing though.
Old May 30, 2006 | 09:58 AM
CRXsi's Avatar
Check the tailight fluid while you are at it...and by the way many manufacturers actually do have replaceable muffler bearings on their variable flow mufflers, dodge doesn't yet. Acura and Mazda however do. The bearing is a for the flap that actually opens depending on power demand and I do know the bearing is a serviceable part if one needs to replace.
As for your plugs and wires...go ask the parts department at your local dealer and see if you stump them or not also
Old May 30, 2006 | 10:49 AM
Toto's Avatar
If I asked some of the dealers I have been to, they probably WOULD try to find sparkplugs and wires for the diesel.
Old May 30, 2006 | 12:07 PM
Patriot2500's Avatar
Guys, your neglecting to tell him about the catalytic converter fluid also. That has to be full in order for the truck to start. Personally, I run Bosch super duper platinums in my truck.
Old May 30, 2006 | 02:25 PM
TonyB's Avatar
What about the kanuter valve?
Old May 30, 2006 | 05:15 PM
timcasbolt's Avatar
Most of the dealers I'm familiar would gladly take the truck in for plugs and wires. Then keep if for three days and charge you $1200 plus rental.
Old May 30, 2006 | 05:18 PM
Red3quarter's Avatar
I think thats a 2nd Gen Option only. On 3rd gens it was replaced by a micro-converter.
Old May 30, 2006 | 08:00 PM
Jmac's Avatar
And don't forget about the 30K service interval for the flux capaciter. As long as that thing is working you can hit 88mph and go back to the future!!!!!!
Old May 30, 2006 | 08:29 PM
cowboy133's Avatar
While your in there you might as well rebuild the carburator too. also check the diesel enhancement valve, if it is plugged you will have to change the fuel hand crank.
Old May 30, 2006 | 08:31 PM
dodgetech77's Avatar
Originally Posted by Toto
Hi All
I believe your particular year also has a cap and rotor
Old May 30, 2006 | 11:25 PM
PEAKSTRYDE's Avatar
TOto
ARE YOU SURE YOURS IS AN '04?????????????
IF you have the '04.5 like mine then besure you you pull off the intake and COAT (use atleast 1/2 of the jar) the turbo fins with peanut butter (RICH AND CREAMY, JIF IS MY PREFERANCE). Once your engine is upto operating temprature the peanut butter will slowly melt, going into/thru the turbo and into the muffler bearings for lubrication.
FOR BEST RESULTS THIS HAS TO BE DONE AT LEAST EVERY OTHER DAY..................................
