pitman arm
Old Apr 30, 2009 | 05:07 PM
stroker101's Avatar
pitman arm
did a serach but...
where can i purchase a 45* pitman arm? the stock one on my trk and the way the tie rod bolts to the top looks like too much stress on the tie rod.
saw a pic on here of a 45* angle pitman arm so i thought i would try it.
Old Apr 30, 2009 | 05:59 PM
D45's Avatar
D45
I would just buy a pitman arm for a 3" lift.....
Old May 1, 2009 | 10:37 AM
stroker101's Avatar
so i called a vendor, and the technician said that i didn't need a new pitman arm. he said the stock arm was good for the amount of lift i added.
they never heard of any tie rod end failures at the pitman arm becuase of a 2" leveling kit being added.
how many of you have changed the pitman arm becuase the angle seemed be too much? i would rather the tie rod be mounted from the bottom. am i just being too ****? lol
thanks
Old May 1, 2009 | 12:10 PM
enafzige's Avatar
The one that's used with the '08 steering tie rod upgrade has an angle to it...although I'm not sure it's exactly a 45°. It's only about $50 if I remember.
--Eric
Old May 1, 2009 | 01:44 PM
stroker101's Avatar
that's probably the one i remember seeing. i guess it would be ok to install it seeing how it's a replcement from a TSB/RECALL.
input and knowledge needed...
Old May 1, 2009 | 05:45 PM
Ace's Avatar
Ace
I believe the only aftermarket drop pitmans you'll find start at 4" and that's why they say you don't need one for 2". The area around 2-to-4" of lift seems to be a problem for draglink geometry. I have a 4" pitman with spring spacers on mine. The PO had the pucks put in before I bought it. I think they are at least 2", maybe more, but it works much better with the drop pitman than it did before and the draglink/track bar are pretty close to parallel. Here's a pic of the spacer, you can see it at the right edge of the pic:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_13.JPG
Old May 1, 2009 | 07:39 PM
stroker101's Avatar
the draglink and track bar on my trk are very close to being at the same angle even with the 2" spring spacers. but the way the tie rod bolts to the pitman arm just seems to be in a bind. if for any reason this truck catchs' some air, it would probably fail.
i may still order a replacement arm from dodge or get a 3"-5" lift arm after reading your reply
exsanguinate
Dec 14, 2009 04:13 PM
BigDan
Jul 8, 2006 11:04 PM
BigBlue
Sep 21, 2004 09:44 PM
BigBlue
Sep 18, 2004 02:13 AM
royalnine
Jul 18, 2004 08:56 PM
