Paint burning off of rear end cover
That picture of the hitch is actually mine not Luvnacumns. Anyway I really like it. Easy to adjust and looks great. I have the 10,000lb capacity hitch with 1500lb tongue weight and I have pulled 9000lb boat with 500lb tongue weight easily.
Its called a Rapid Hitch...here's the link to their site. You can find them on ebay sometimes or local hitch shops usually carry them. The hitch coemes in three lengths. Mine is the middle one, and make sure you get the locking pins. Total should be around $225.00+-.
http://ultrahitch.rpmsolutions.biz/index.cfm?section=73
I certainly agree that heat can cause paint to crack or peel. The paint they should be using on the rear diff and cover should be a high heat paint and shouldn't fail like it does consistently on our trucks. You can easily pick the paint off a brand new diff cover and it is obvious that they aren't prepping it very well before they spray it. Just tightening the cover bolts causes the paint to crack off.
It's certainly worth looking inside the pumpkin to make sure there are no problems, but as I stated before, it is more than likely poor paint work.
If you wanna know what temp. your differential is running, put a temperature tape on it. It has 5 white squares on it that are in correlation to maximum temperature reached. Just put it on and drive the truck for several weeks. Pull with it, work it hard as you want to. Then next time you get under the truck, see which squares have turned black, thats your highest temp.
As for the paint, paint thats heated indirectly(hot fluid) will usually discolor... I see it all the time on new engines after they are warmed up and loaded really hard the first time. That Hy-Tec cover is sweet!!!.. Thats what I'm gonna put on my truck when I change differential fluid.
Does anybody kknow if the clearance issues with the front differential cover have been corrected yet?????
my 4x4 with 4:10's burnt it off like candy,
i put cheap paint on, then high temp exhaust paint, and finally BBQ grill paint on it,
because the 4x4 sat so high, the rust was prominent.
maybe sanding it would have made it last, but it baked them all off.
my 4x2 3:73 is the same after 12k miles and only ~1k of them towing heavy.
can't see it, don't matter.
I agree with poorman.. another idea i had was temp sticks.. ( like a big crayon that is white at normal temp and melts clear when designated temp of mark is reached) we use them a lot when we have to preheat the iron before welding. They are cheap and available at any welding store or hardware store that sells welding equip.
I monitor my rear diff temp with a gauge - never seen it go higher than 150*, but expect closer to 200* when towing heavy in the TX heat.
Peeling paint is one thing, but it shouldn't be discoloring/burning due to heat - that'd be well over 200* for sure, which isn't right.
I think 75/140 is the way to go, and of course RP or Redline helps, too.
On a related note, my pet paint peeve with DC is how they leave so much raw steel uncoated under the truck... I mean gimme a break, with the hydro-based paint technology we have - the environmental costs of painting the parts become insignificant in relation to the old paint systems!
