P2509 Fault Code
Old Jan 8, 2011 | 11:50 AM
TXCTD01's Avatar
P2509 Fault Code
I went and turned the truck on this morning and my engine light came on. I took the truck to Autozone and they told me it was Code P2509:
Power down data lost error
ECM has detected a loss of power condition
Probable Cause
Poor Electrical Connection
Battery Fault
Battery Disconnected
The truck had no issues starting this morning so I don't think it's the battery. I did have the guy check the batteries but he checked them while they were still connected. I thought you had to disconnect the batteries to properly check them?
If anyone has any ideas I would appreciate it.
Old Jan 8, 2011 | 12:28 PM
Mindy's Avatar
Probable Cause
Battery Fault
Got the same code 2 wks ago if I didnt plug my truck in. Then I got a "charging system low voltage" warning. Now my truck is in my yard with a bad cable connection that I need to change. But according to my battery tester my batteries are fine.
Old Jan 8, 2011 | 12:44 PM
TXCTD01's Avatar
I just cleaned both terminals on the batteries and the ground on the body and the code went away. I hope that keeps it fixed. I might go get the batteries tested elsewhere. Good luck!!!
Old Jan 8, 2011 | 01:13 PM
Mindy's Avatar
Thanks...hopefully when I change the cable clamp I will be back on the road. Till then Im going to be driving a Ford (eek!)
JARHEAD
Mar 5, 2020 01:08 AM
ROOSTER108BM
May 27, 2007 11:39 AM
Nuttymopar
Apr 26, 2005 08:16 AM
kertoncol
Jan 19, 2004 10:18 AM
