p2149
Old Jun 1, 2014 | 03:07 PM
Falcon1's Avatar
p2149
Got this code did some reading and can't figure it out . Voltage to injectors 1,2,3, no voltage to 4,5,6, harness to injectors omed good injectors omed good ether wiring from ECM or the ECM?
Old Jun 1, 2014 | 04:20 PM
BigIron70's Avatar
Cummins Guru
Sounds like ECM, follow diagnostics may be of some help. You can also disconnect injector one at a time insulate wire connector so they do not short and clear code. Start engine if code doesn't return then replace that injector
Old Jun 4, 2014 | 09:57 AM
Falcon1's Avatar
After two days of ohming wires and tracing. Looks like the ECM took a dump on me.
Old Jun 4, 2014 | 11:36 PM
pind's Avatar
very carefully inspect the wiring harness where it makes short loops, and where it runs close to injector lines / bolts. the wiring is somewhat chintzy and I have seen rubs through the insulation, allowing for a short to ground situation, causing the same code you are experiencing.
don't go nuts on the ecm just yet.
good luck
Old Jun 15, 2014 | 08:23 AM
Falcon1's Avatar
Got another ECM and had it flashed. Installed it and still having the same problem.
Old Jun 15, 2014 | 03:13 PM
Falcon1's Avatar
Turns out injector 5 is shorting out. Moved it to #3 and code followed it from#5 to #3 p2146 code.
haulin-rv
Oct 17, 2008 10:39 AM
redgoat05
Sep 13, 2007 12:52 AM
RockcrawlingTJ
Oct 29, 2006 10:41 PM
Merritt
14
Aug 6, 2006 09:27 AM
