p0251 help
Old Jan 26, 2007 | 05:17 PM
reecegr's Avatar
Question p0251 help/information
I know its P0251 Injection Pump Fuel Valve Feedback ,just a couple of questions,truck loses power smokes a little and dies,motor is at full temp every time it died(6 times in 4 days)
#1 what do you think it is pump or relief valve
#2 is it covered under the 7/70 or 100 cummins or not at all
truck has 55k on it and not many problems stock since 20k quad standard before that.
thanks in advance
Old Jan 26, 2007 | 09:11 PM
reecegr's Avatar
I thought this would be an easy one, for this forum
Old Jan 27, 2007 | 10:09 AM
53 willys's Avatar
I say it's the fuel pump. but if the pumps test ok then my next guess is the Fuel Control Actuator.
let use know what you find.
BTW, yes it should be warranty.
Mark
Old Jan 30, 2007 | 02:43 PM
reecegr's Avatar
you were right ******(Fuel Control Actuator)the dealer ship called today and said that's what it was,overnight air from chicago will be fixed tomorrow.would you happen to know if that would be covered under the 7/70
or 100k cummins?
I am well over the 36k.
Old Jan 30, 2007 | 07:21 PM
53 willys's Avatar
oh yeah that is warranty I'm sure ANY thing on the cummins engine and fuel system is covered on the 100k 5y.
Mark
Old Feb 6, 2007 | 09:08 PM
reecegr's Avatar
Angry
well problem is back p0483 and p0521 truck dies,yes it was under warranty but doesnt seem to fix anything.
Old Feb 6, 2007 | 09:38 PM
53 willys's Avatar
These are different codes this time!!!!
P0521-OIL PRESSURE SWITCH RATIONALITY
WHEN MONITORED
While the key is on.
SET CONDITION
Oil pressure is detected with engine RPM = 0 for 30 seconds .
POSSIBLE CAUSES
  • Oil pressure switch
  • (G6) Signal circuit open
  • Intermittent condition
  • ECM
P0483-FAN SPEED
WHEN MONITORED
While the engine is running.
SET CONDITION
The actual fan speed is less than 75 RPM or more than 4000 RPM .
POSSIBLE CAUSES
  • Other DTC's
  • (K161) Signal circuit short to (K668) 5-volt supply circuit
  • (K161) Signal circuit open from ECM to fan clutch assembly
  • (K668) 5-Volt supply CKT open from ECM harness connector to fan clutch harness connector
  • (K161) Signal circuit shorted to (690) return in the harness
  • (K161) Signal circuit shorted to voltage
  • (K161) Signal circuit in ECM shorted to ground inside ECM
  • (K161) Signal circuit shorted to voltage in the ECM
  • (K668) 5-Volt supply circuit in ECM
P0483 seems to be a popular code these last few weeks
I don't have much advice for those codes......
Old Feb 7, 2007 | 09:02 AM
reecegr's Avatar
sorry for the typo its the same 0251 but thankyou for the reply,I guess we will see, dealer again friday.
Old Feb 7, 2007 | 10:56 AM
53 willys's Avatar
last time I had my oil changed the service writer told me they have had a lot of problems with Automatic trucks throwing intermittent codes for no reason hopefully this is not whats happening to yours.
Steve034x4
Jan 21, 2014 09:48 AM
CharlieNH
May 23, 2012 03:16 PM
redscooter
Mar 31, 2009 12:13 AM
mm73
Mar 11, 2009 03:06 PM
Robin Shaw
Nov 24, 2003 02:16 AM
