06 Mega all over the road HELP
Old Feb 1, 2007 | 08:14 PM
slickr1's Avatar
My 06 Mega with 10k in miles seems to be floating all over the road when I drive. When I am going down the interstate I can move the steering wheel 1/2" left or right but the truck keeps on going straight. The truck is a 4x4 with stock trim.
Any thoughts???
Old Feb 1, 2007 | 08:42 PM
kelley15's Avatar
Tires over pressured ,out of round or unbalanced? I would start with the tires first ,then keep on looking.
Old Feb 1, 2007 | 10:12 PM
donhov's Avatar
Sounds like it might be a problem with the steering box itself. I would get it to the dealer ASAP. Sounds like a serious safety issue. You might look under to see if anything is loose but it should be a warranty issue and if they tell you to drive it as is I would request that they give you a letter to that effect.
JM02.....Don
Old Feb 2, 2007 | 08:00 AM
FishingFather's Avatar
I would check tire pressure first, then if you don't find anything, off to the dealer. It should be covered under your warrantee.
Old Feb 2, 2007 | 08:05 AM
rockcrawler304's Avatar
I doubt tire pressure. If you can turn it a 1/2 turn either way and still drive straight, you have something wrong in the steering system!!
Old Feb 2, 2007 | 11:01 AM
FMB's Avatar
FMB
Originally Posted by slickr1
I can move the steering wheel 1/2" left or right...
If you can turn it a 1/2 turn either way...
Big difference between 1/2" and 1/2 turn.
Old Feb 2, 2007 | 11:37 AM
My bad I guess that's what I get for reading when I first get to work. I needed more
I'm better now so go ahead and check tire pressure first!! (Then maybe the dealer)
Old Feb 2, 2007 | 11:43 AM
slickr1's Avatar
Thanks all, it is going to the dealer next Wed. I will keep you posted on what they find.
Thanks again
Harmon
Old Feb 2, 2007 | 12:29 PM
DrDiesel's Avatar
Wink
Thanks again
Harmon
I`m sure this has crossed your mind, but have your set your front tire pressure to 65 plus PSI. Low tire pressure will cause all sorts of steering problems... Just a thought...
Old Feb 2, 2007 | 04:17 PM
04ctd's Avatar
i kept my 04 at 45 psi due to rough roads, helped ride a bit, maybe lost .5mpg
i would look at the "rag joint" if these trucks have one.
would be between the firewall & steering box.
Old Feb 2, 2007 | 08:36 PM
Lost Texan's Avatar
I have a 07' that is doing the same thing and it is driving me nuts. The truck only has 300 miles on it. I ordered a DSS setup and will install it tomorrow morning to see if it can rectify the problem. I would rather try that fix before letting the dealer tear into a brand new pickup. If it doesn't help, I'll take it into the dealer. Please let me know what your dealer finds.
LT
Old Feb 2, 2007 | 08:42 PM
Hotazdiesel's Avatar
Maybe this thread will be of some help.
http://carsondodge.com/forums/showthread.php?t=181
Old Feb 3, 2007 | 01:30 AM
Hounddog's Avatar
That Carson thread is about DEATH WOBBLE.Differant from what is being posted on with these new trucks.Sounds like steering box issues.Too much play.
Old Feb 3, 2007 | 08:34 PM
Lost Texan's Avatar
Well I installed the product this morning and WOW, what a difference. I highly reccommend it. I have a feeling (and hoping) that it will prevent future issues in the years to come.
LT
Old Feb 4, 2007 | 06:44 PM
les1cam's Avatar
DSS system
What's this?
