overunning clutch to prevent chirp on shutdown
Old Sep 24, 2007 | 01:00 PM
OX1's Avatar
OX1
Worth getting? I like the chirp, but not sure if it's hurting anything long term.
http://dodgeram.info/tsb/2006/09-004-06.htm
Old Sep 24, 2007 | 02:29 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
That chirp is normal and does no damage at all. Simply the Cummins stops spinning real fast at shut off because of high compression. The Alternator, AC compressor, water pump etc....are still spinning and that chirp is from the belt stopping them almost as quickly as the engine.
Don't even give it a moments thought
Old Sep 24, 2007 | 11:46 PM
Raspy's Avatar
Yeah, it is no problem and adds a little character. Mine stopped doing it about 40,000 miles ago so I guess the belt is a little more slippery now. Too bad.
John
Old Sep 25, 2007 | 01:17 AM
no_6_oh_no's Avatar
Yes and no.
The chirp is not hurting anything, but, the conditions that cause the chirp can and do cause problems.
The over running clutch is to address the belt jumping 1 or 2 grooves on the damper pulley. The sudden stop creates slack in the belt when it loads/unloads the tensioner pulley quickly. It can cause the belt to walk off the damper pulley which puts it into contact with other accessories and shreds the belt.
Sometimes the cause is a slight misalignment on one of the pulleys, sometimes it is the belt, and sometimes it just plain bad luck. As the tensioner wears the chirp goes away but the slack thrown in the belt gets worse.
As far as not giving it a though, picture what a flapping piece of belt could do to the underhood components if it got loose.
sluggo42
15
Nov 14, 2010 11:18 PM
CmminsBeast
17
Mar 12, 2007 02:25 PM
Rocket95
Jun 14, 2003 02:27 PM
ramlovingvet
Jan 9, 2003 07:54 PM
sixtogo
Nov 21, 2002 10:23 PM
