overdrive options?
Old Jul 22, 2008 | 05:46 PM
loneranger47's Avatar
Question overdrive options?
2006, 5.9 Cumminis, NV5600, standard cab. Any overdrive suppliers beside GV? The truck has a split drive shaft already, so a divorced unit is a possiblity. Shopping price and hard to believe GV is the only game in town.
Old Jul 22, 2008 | 08:34 PM
Jim O's Avatar
Is your truck a 4x4 if so the US gear calls for shortening the rear driveshaft and lengthening the front one. It goes between the transmission and the transfer case. I have driven both the US gear and the Gear vendors and the Gear vendors is what I bought I have over I00.000 miles on it with out any problems.
Jim O
Old Jul 23, 2008 | 07:40 PM
rich's Avatar
06 is g56 tranny and none of them recomend towing heavy
Old Jul 24, 2008 | 01:23 PM
enafzige's Avatar
I was in the same dilemna as you. US Gear doesn't offer anything for the G56 trans. The Gear Vendors unit cannot be used with the exhaust brake engaged.
There is a company called Mitchell Manufacturing that makes very heavy duty OD Gear splitters...although, I think they stopped production of some models.
I found one used, model 3500D, that is an 18.2% overdrive. It is rated conservatively at 35,000 lb GVWR, and is synchronized gear-to-gear drive.
I'll post pictures when I finish up the details of installation. It mounts in a divorced configuration, and the rear drive shaft has to be shortened.
With the OD engaged in 6th, I'm at 1650 rpm at 75 mph, and 2300 rpm at 100.
--Eric
72demon440
Apr 27, 2007 10:45 PM
olgraybeard
Mar 24, 2003 06:32 AM
pappyman
Dec 17, 2002 06:41 PM
marsh1946
Dec 5, 2002 12:55 PM
