Oil question
Old Oct 4, 2007 | 09:23 PM
RattlerSkin's Avatar
Oil question
I am getting ready to do an oil change in the truck, but I came up with a question: I currently live in northern VA where the temps get to about 50 at night right now. I use Rotella in the truck, but I am getting ready to change duty stations out to 29 Palms, CA in December where the daily temp average is about 50 during Dec-Jan. Should I just stay with the Rotella since that is what I have been using for a while now, or should I rotate over to a synthetic since I will still be in Virginia for a while?
Old Oct 4, 2007 | 09:40 PM
soulezoo's Avatar
DTR 1st Sergeant
Mild temps all the way around. If you like Rotella, you can stay with that and be happy. I wouldn't worry about feeling like you HAVE to have synthetic because of temps unless you were one of our friends in the great white north!
Old Oct 5, 2007 | 06:48 AM
D-Roc's Avatar
Stick with Rotella for sure, you will be fine with it.
Old Oct 5, 2007 | 09:18 AM
Alright, I appreciate the help
Old Oct 5, 2007 | 10:03 AM
Roperteacher's Avatar
I don't live far from there and it's all good!!! Is the Rotella your using the NEW CJ formula????? Just curious....
Old Oct 5, 2007 | 02:01 PM
Spooler's Avatar
Just keep on using the Rotella. I see no need to change oil unless you are in a realy cold enviorment. I would only get worried if temps are in the teens constantly.
Old Oct 5, 2007 | 02:48 PM
louielouie's Avatar
The temps in the Puget Sound region have been cooling down and since a synthetic 5w-40 is approved I switched my CTD & two Bimmers over to the synthetic Rotella 5w-40 (CI-4+ rated) from Walmart @ $16.24/gal. It was tough carrying 6 1-gal jugs and only slightly messy changing all three of them in one afternoon.
ian515
Oct 16, 2007 07:02 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
