oil pressure sensor
Old May 23, 2006 | 11:13 AM
Lee Jolly's Avatar
oil pressure sensor
How would I go about hooking up an oil pressure idiot light on an 03? This is on an engine swapped into a ford so I dont have the dodge cluster or body control module, etc.
Basically I have the engine and ECM. If it takes an aftermarket oil pressure sensor then I'm fine with that, but I dont know where to install it. Any help would be appreciated!
I understand a real guage would be better but I specifically need a light.
Old May 24, 2006 | 07:36 PM
nickleinonen's Avatar
for oil pressure access, you can get it off the filter pad [standard 1/8"npt fittings] or the left side of the block. there are 2 m10x1.0 orb ports, and 2 m14x1.5" orb ports. one of the 14mm ones are blocked by the filter pad bracket, and the other is occupied by the stock switch
the stock "sensor" should work. it is a glorified 6psi hobbs switch. if you just want to use a hobbs switch, you can pull the stock switch, use a m14x1.5 orb to npt bushing and put it there. set the hobbs switch to 10psi and you will be set.
Old May 25, 2006 | 03:04 PM
Lee Jolly's Avatar
Thanks for your help!
Redlinear
Feb 14, 2013 01:10 PM
Bobcat698
Mar 25, 2008 09:42 AM
tyssniffen
Feb 11, 2006 01:28 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
