Oil Pan
Old Sep 5, 2010 | 10:28 PM
johndeere01's Avatar
Oil Pan
Hello, I have a 2003 2500 QCLB 4X4 auto that has a hole in the oil pan thanks to the wonderful northeast weather, my question is can the oil pan be canged without pulling the motor completly out? If so can ya tell me how or how not, thanks for the help
dennis
Old Sep 6, 2010 | 06:52 PM
no one knows?
Old Sep 6, 2010 | 07:21 PM
JRD's Avatar
JRD
No the engine needs to be slightly lifted to remove the pan. Unbolt it from the mounts. That should give you just enough room to remove it.
Old Sep 8, 2010 | 03:39 AM
NickBeek's Avatar
The engine needs to be lifted as much as possible in the engine bay. Then drop the pan bolts. This should give you enough room to work inside the pan and remove the oil pump pickup tube. Once that is removed, you can get the pan out. Reverse to install.
04ctd
Apr 21, 2008 03:16 PM
EverydayDiesel
Nov 11, 2007 09:33 AM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
