Oil coming out of turbo
Old Jan 8, 2017 | 03:46 PM
1990scarab's Avatar
06 5.9 oil coming out of turbo at idle what is my problem
Old Jan 8, 2017 | 04:04 PM
johnh's Avatar
something is worn out!
Old Jan 8, 2017 | 05:17 PM
madhat's Avatar
Administrator/Jarhead
I would seriously suggest that you stop running your truck. If there is an internal leak, then the engine can be fueled by the oil, and you will have a run away truck- you don't want that to happen.
If it is an external leak only, it could be from improperly fitting oil feed/return lines. If it's leaking from inside, it's a seal.
Old Jan 8, 2017 | 05:53 PM
gcssr's Avatar
Remove the drain line, see if oil runs out, of the turbo, be prepared to catch it, check if drain is clogged, blow gently back into the engine, if it isn't plugged then see if u have end play,
Old Jan 8, 2017 | 10:21 PM
BigIron70's Avatar
Cummins Guru
Coming out from just where? Outlet? inlet? drain tube? oil feed line? Photo of where oil leak on turbo is located maybe helpful.
Lark
Mar 8, 2007 04:58 PM
BigWaylon
Dec 13, 2006 09:55 AM
bluesfan01
Nov 16, 2006 08:07 PM
eddiewalker
Apr 10, 2006 08:19 PM
white dually
Nov 27, 2005 12:49 AM
