Oil Analysis Results....
Old Aug 30, 2007 | 09:46 PM
Buckshotmckee's Avatar
Question Oil Analysis Results....
so how do these #s look? This was the 1st oil change on the new truck with Valvoline premium blue, 15w40, 5k miles on the oil. This was also with running 1 quart of 2-stroke oil per fill-up.
Iron-21
Chromium-1
Lead-2
Copper-5
Tin-0
Aluminum-5
Nickel-0
Silver-1
Silicone-13
Boron-40
Sodium-15
Magnesium-247
Calcium-2195
Barium-0
Phosphorus-1024
Zinc-1303
Molybdenum-23
Titanium-0
Vanadium-0
Potassium-0
Fuel(%vol)-<1
VIS @ 100 C cst-14.5
Water(%ofvol)-0
Soot/Solids(%wt)-0.4
Coolant-No
Old Aug 30, 2007 | 10:59 PM
This was not with the factory fill oil, but was with the 5-10k service I did.
Saturday were going to Santa Barbara to the zoo, Sunday no plans, Monday I'm helping a buddy move about 6yds of dirt with the truck. Let me know were your going to be or if ya want to meet up for coffee or something.
Tye
Old Aug 30, 2007 | 11:07 PM
drewblood's Avatar
https://www.dieseltruckresource.com/...entid=13496&d=
check this link out
Old Aug 30, 2007 | 11:14 PM
drewblood's Avatar
well it depends Im pretty sure a 5.9 is still considered heavy duty engine cause its used in industral applications
Old Aug 30, 2007 | 11:32 PM
dfranks's Avatar
Silicon is way too high for that low of miles. Switch out your airfilter and DON'T use a k&n. My last silicon was 3 with 18k miles with a bypass. You should be no more than a 5PPM of silicon if you are changing at 5k.
just my .2 cents for more info check out "bob the oil guy"
Old Aug 31, 2007 | 07:13 AM
I'm not running a K&N! I'm running the new AFE Pro Dry 'S'.
Old Aug 31, 2007 | 09:47 PM
Nevada's Avatar
My first analysis (factory fill) on factory air filter had a silicon number of 31, next oil change dropped to 18, from then on they have all been around 3. I wouldn't sweat it. BTW, I changed to an old style AFE filter in the factory box (NOT the Pro Guard) and there was no change in my silicon numbers.
Old Sep 29, 2007 | 02:51 PM
CrazyCooter's Avatar
My silicon was 34!
I'm using an Amsoil drop-in.
Oil is Amsoil AME 15-40and EAO99 filter run 10500 miles.
Copper was 186.
Iron was 102.
I guess my engine is on it's way out at 15000 miles
Oh well..........what $10K
Old Sep 29, 2007 | 03:37 PM
jrussell's Avatar
If it's only the 2nd oil change I wouldn't worry too much about the Silicon, but your Sodium (salt) levels look a little high. Maybe the air filter has a leak where it mounts on the plastic AFE tube?
Old Sep 29, 2007 | 03:41 PM
jrussell's Avatar
Originally Posted by CrazyCooter
My silicon was 34!
Copper was 186.
Iron was 102.
That sucks.
My Iron has been in the mid 40's the last two times, but I'm thinking that may be due to opening up the system for all the turbo work that's been done.
Old Sep 29, 2007 | 05:33 PM
I called AFE about it since the Pro Dry 'S' is a new product, and after a week they called me and got my address and sent me a brand new Proguard 7.
DaveB.inVa
Aug 11, 2010 07:45 PM
Buckshotmckee
Mar 29, 2008 05:04 PM
Baja
Feb 12, 2007 10:58 AM
Bobcat698
Nov 1, 2005 07:05 PM
030303
Feb 28, 2005 09:02 AM
